1x10 conversion - Leonardi Racing/ General Lee Adapter
1x10 is great, you don't need to be a world cup XCO racer, first ran 1x9 in 2010 (with a chain guide) love it even more now without the clutter of a chain guide with my wolf ring.....
No chain dropping on the wolf ring without a guide? Been looking at the longer teethed (?) rings, but still nervous about not getting a guide with it.
  • Replies 157
You don't need a chainguide when using the wolftooth chainrings. A clutch type derailleur is recommended but with my past race and from other reviews it just serves as extra insurance if you have correctly done the chain tension.
Also need to mention that the race was done on a HT, which I think makes it even more impressive that the chains stayed on without the clutch derailer.
A HT will hold chain tension better than a DS.
what size front chainring you all running?
currently my 2x10 is 26/39, but I never use small blade, so i'm thinking of getting a 39 wolf tooth
On my 1*9 I use a 32 (Probably because they are on most triples ...) with an 11-34 cassette. Find it ok for most riding .....
Hi.
I have a 30 on there. My normal route at Tygerberg has a 26% gradient and I based the chainring size on that........for now.
The more I ride, and stronger i get, the more I will consider going 32 or 34. But for now, with my 11-36 cluster and the type of rider and riding that I do, it is perfect!
  • 1 month later...
So what is final consensus about converting 2x10 to 1x10 and what rations
I currently have a 2 x 10 XTR 11-36 back and 26/38 front. I still use the 36 back and 26 fronts on steep climbs now and then.
Which woolftooth chainring would you guys suggest?
I it necessary to do the cassette conversion or can I keep the 11/36?
I don't have a clutch RD. Do I need one if I change to woolf chainring? What about the chainguide?
I did read entire thread. Using a 34 up front and a 11/36 back means you are a seriously strong rider in my opinion. I'm wondering if the 32 up front would not also be too grueling on the climbs
Looking forward to comments
that's what I have at the moment. 32 and only a 32, with an 11-34 at the back. If I can make it up the climbs, to the mast in Tokai, on my Reign X (yes, I have done it a few times) in my state (overweight - 102kg and unfit) then you can, Jaco.
To put it in perspective - I'm pedalling 125kg up the hill EVERY TIME I go out. 15kg bike. 102kg me. 8kg gear, water & camelbak, helmet shoes etc. If I can do that with a 32 tooth, 11-34 at the back, then it's more than sufficient. I have a 34 in the post. It's time to HTFU, mate.
