Ok, so a lot of you will propably laugh at my question, but here goes anyway. Apart for the frame; wheels and fork (obviously), is it possible to take your 26'er parts to build on a 29'er frame, or do you get specific groupsets for 26'ers and 29'ers??
Groupsets are the same. you might just need to get new cables and hydraulic hose, as the 26ers cables might be too short.
As for the rest, it will all fit
yep, just do it... no issues apart from brake hose lenght as you may need a longer one to the rear brake.
I would fit new cables if doing a rebuild
Edited by shaper
Just some things to consider:-
1) Do both frame's take the same Bottom Bracket ( some use the 'std' screw in and otheres press fit)
2) is the Front Derailleur OK (sometimes low mounts won't work on strange shaped frames etc.), even sometimes it needs a 'direct mount' .....
3) Does the 'new' frame come with a complete headset (often times the bearings/spacer magafter could be different)
4) As already mentioned brake hose length may be an issue, I would also use new cables and housing
