Disc brakes jamming
Klipspringer
Hi fellow hubbers, why does this happen? On my MTB it has now happened twice, hydraulic disk brakes, recently serviced. Yesterday had no other option than removing the brake pads. It happened on a fairly flat section, felt like I was pedalling in water. Someone said it can be an air bubble in the system - is this a possibility?
And then , how to unjam it without removing the brake pads? ( bike is now at my LBS, the mechanic will look on Monday).
What brakes are they, make & model?
Lucky for you avid sells rebuild kits but to be honest if you are paying the lbs to do the work after labour and parts are added up a better option perhaps is just getting a whole new set of some of the current entry level Shimano Deore brakes. Sell the Avid's for spares in the classifieds to help subsidize the new brakes. Or get the seals kit and do the work on the Avid's yourself, plenty of info on google for working on them.
I also think it is a master cylinder issue.  Might be a quick and easier fix than you think.
And while Avid might not be the best out there, there is nothing in principle wrong with them.  No need to sell because of one hick-up, these things happen, it's mechanical.
Yesterday was pretty hot, so if the flat section was in the open it could very easily just be a bad bleed. Find someone who can bleed them properly before you just moer them in the bin.
And if you do throw them away, throw them at me. My SS needs brakes.
  • 6 months later...
I had this with my Elixir 5's.
It was just a bad bleed - a bubble in the middle of the hose. What happened was that the brake pads were only slightly pushing against the rotors. At first it was ignorable. As I continued riding, the the heat build-up in the callipers increased the pressure, causing more drag, which in turn, caused more heat build! Soon I had a seized brake (luckily the rear one).
Some waiting and break-pumping later it was fine again to ride back home. But in the end it required the TLC from the LBS.
