ok so got the new mtb and asked the bikeshop to covert it to tubeless. Got home yesterday not even haven gone for a ride yet and back tyre as flat as can be with white fluid all over my floor......
how can I determine if they converted it to tubeless......and why the milky fluid on my floor?Angry
They did convert and the conversion didn't take, the milky fluid is the sealant and you now don't have a tube, try pumping it up again and see if it stays inflated?
After a conversion it's best to ride the bike stratight away, helps the sealant slosh about and seal.
Wooohoooo - best news I have seen this week!!!!! No more excuses now.
As TitusTi says my experience is also to ride it and then ride some more and more and ...... It does 'settle' down pretty quickly!
But it is better to ride slowly around the house a few times . It ensures that the fluid seals all the holes as there are always a few leaks first time around . The white stuff lying all over the place is the sealant .
hel niemand het dit vir my gese....was ook bietjie moeilik om om die blok gaan ry het met al die reen....Cry
Hey pump that wheel and go ride now ............ oh that damn work thing probably gets in the way sorry Ouch
If you don't get it inflated with a hand/floor pump use a bomb (OK OK I know some say it will freeze/coagulate/stuff up the Stan's but I done plenty like that and I'm OK, but then again maybe I'm not ........)
I have only changed a tubeless tyre once and there were no sealing issues at all.
Is it different when using non-ust tyres? is it more difficult to get them to seal?
Not really . I always go for a short ride on a bike after the conversion and it always seals perfectly . It is more difficult to get a proper seal on old tyres and rim tape that got old sealant all over them .
That tyre should inflate using a floor pump but use a bomb then if you must !
Just this morning I was thinking after 2 roadbike punctures yesterday (OK so the one tube LittleBen gave me had a puncture already grrrr!) when last did I have an MTB puncture ........ it's been like forever! Tubeless rules (now .......).
ja het ook nog geen probleme met tubeless gehad...tot nou...grrr
so sal na die naweek eers vir die eerste keer op my nuwe fietsie kan gaan ry..wow dis sad...die ding al vir week ek nog nie eers gaan ry
kan ek nie net die tyre by die garage gaan op pomp nie...geen manual labour....just push the button
Dog jy's 'n mountainbiker....QuestionQuestionQuestionQuestionQuestion
Bang vir nat word???   Vet smelt nie in water nie......Evil%20Smile
uhm okSleepy
Nevermind die tubeless storie' date=' waar is die kiekie van die nuwe mens aangedrewe trap vervoermiddel?
kiekie le by huis want glo nie daarin om aardse besittings af te show....maar dit lyk iets soos die volgende....
Tog werk jy hard om die beste "aardse besittings" te kan bekostig.
Anyway, BAIE nice. Many happy "upright" miles.
