  On 10/30/2015 at 11:41 AM, geraldm24 said:
Here's an order form - a google sheet that you can complete online with your order. It will calculate the "estimated VAT", assume handling is R80 or what ever it is from FedEx and give you an estimated value for each order is worth. Obviously, the more that order, the cheaper the shipping value will be.
If you order more than one item, the final amount will be summarised on the pivot table (next tab). Hope this helps.
Edit: fill the form in online - it saves automatically. complete the yellow portions.
Thanks. I note that the formula calcs shipping based on the number of orders. OK then to overwrite your data?
  • Replies 149
You can overwrite it.
If you're order a single lens, it's fine - but if you're ordering multiple lens with different values, you'd need to specify the link to each lens.
the idea with the link, is so that the person ordering & paying online knows exactly what is to be ordered.
Guest notmyname
Dudes I'm just traveling back to jozi from Tzaneen. I'll read thus thread and add my selection.
VanZyl, I am doing the ordering so I guess it's me. Have you read the thread? I will order and get the lenses once I have received payment for at least the couriering and charges SA-side. We can then meet up and final payment can be made with handover of lenses over coffee.
That OK? If so, I can PM you some details.
Guest notmyname
Im in chaps. Sorry I've been away from any sort of connectivity.
