Using Spray 'n Cook as chain lube
Red Bird
  • Replies 49
on expresso, must be a true story.  those people KNOW everything
will probably also make a shimano 9 speed chain last forever on a XX1 setup
http://www.oakhillspto.org/wp-content/popcornfriday/popcornsales.jpg
Tried that while camping once. Didn't end well. Was a long walk home with jammed up drivetrain. Every grain of sand sticks to the chain and soon becomes like a big fat slug
Have used spray n cook in emergency. Very good chain lube but overspray is a problem and can be messy. It's high quality lube suitable for high temperature.
Also try casida food grade spray on lube
Have stopped at a garage during a ride to scrounge a few drops of oil from empty oil cans before. Motor oil probably a better chain lube than anything else in a pinch and its ubiquitous.
What is it with these strings? Or is it Friday in December?
I have an amazing suggestion.
How about using this new fangled stuff called chain lube on chains, or is that a revolutionary idea?
You might be on to something there....
Use dipstick oil for an emergency lube.
I thought it was about what do you do when you're out there and suddenly realise you left the chain lube at home....and your chain is screeching for attention.
I prefer to use smooth peanut butter on my chain. Sure there's a bit of chain suck but it's biodegradable and if I put too much on I can just lick it off. Or something.
Also... #overthinking #notaproblem #happyfriday
did you see what that chain looked like they had on expresso this morning???? it was nearly rusted solid! I'm now a firm believer in spray and cook. I mean...to make a chain like that work sweetly again!  I will however only use it should my chain also land up looking like that. :ph34r:
