Garmin Edge 705 - replacement battery?
My Garmin Edge 705 is not holding a charge anymore.
Garmin have stopped supporting this model.
Does anyone know where else I can go to get this battery replaced?
I live in Witbank but go to Johannesburg and Pretoria for business.
Mate did this a while back, he ordered a Newpower99 kit on Amazon and extra battery
$ exchange rate was much better then.
Edited by scotty
Why not find out how much garmin would give you off a new unit if you traded it in?
I did ask Garmin.
Unit is so old they don't offer any trade in.
I guess I am in the market for an Edge 520 now.
Tempting but then I am still in old discountinued technology.
ye I know.  I have the unit, charger, cadence sensor.  The handlebar mount unit broke, so now the 705 is only gathering dust.  have not used it in over a year.
I did ask Garmin.
WHAT!! Was about to call them, well now I am bleak. My one is on the fritz, a garmin edge 25 may be on the cards. Do not have $ for the 520 at the moment.
Thanks for helping.
  • 4 years later...
Reviving an old thread...
A friend recently gave me a 705 that needed a new battery. I started looking into replacements and wasn't keen on importing a battery and going through all the hassles so I replaced the battery with similar item from Communica. We did have to do some soldering and figure out how the pins connect but it booted up.
https://www.communica.co.za/products/li-poly-battery-3-7v-1100mah
I might loose out on some battery life but at R160 and with a bit of work, I have a 705 running.
Edited by hansolo
maybe document the process and post a sticky? I have a Edge 705 that still works well. It will need a new battery at some point
Thats fantastic! My wife has the 800 think it would use the same battery?
If I get it right ill breathe some fresh legs into my 810 as well then.
