Rushdee Posted July 7, 2016 Posted July 7, 2016 Hint # 01: basic frame specs alluded to in the topic title..
DirtyDan Posted July 7, 2016 Posted July 7, 2016 If you sourced the frame locally, then I reckon it's a Hungry Monkey from Dave Mercer.If it's international, then a Commencal META HT CrMo.Next guess would be a Ragley... What do I get?!
Rushdee Posted July 7, 2016 Author Posted July 7, 2016 hint # 03: ISCG'05 mounting tabs. (opted for a basic seat tube clamp-on chain guide instead). Top headset on the right.
Odinson Posted July 7, 2016 Posted July 7, 2016 Dude, you've got the tag "On-One" in the tread header.
Jewbacca Posted July 7, 2016 Posted July 7, 2016 Dude, you've got the tag "On-One" in the tread header.hahahahaha I missed that.... So an On One 4560 then? Nick's missus rides a sexy looking one of those too....
Nick Posted July 7, 2016 Posted July 7, 2016 http://i1127.photobucket.com/albums/l628/stressed_eric1/MTB/20160625_152733_1467889326072_resized.jpg Not a 456 then unless you got the wrong axle
The MTBer Posted July 7, 2016 Posted July 7, 2016 hint # 03: ISCG'05 mounting tabs.[/size] (opted for a basic seat tube clamp-on chain guide instead). Top headset on the right.[/size]http://i1127.photobucket.com/albums/l628/stressed_eric1/MTB/20160623_235508_1467889326916_resized.jpgWhere did you get that chain guide?
Rushdee Posted July 7, 2016 Author Posted July 7, 2016 Not a 456 then unless you got the wrong axle axle is correct
popcorn_skollie Posted July 7, 2016 Posted July 7, 2016 any of the add on goodies could be on one. I'm not googling specs to get the answer. Where's the fun in thatSurprised nobody guessed cotic yet
Jewbacca Posted July 7, 2016 Posted July 7, 2016 axle is correct Not a 456 then unless you got the wrong axle It is a 10mm axle Nick, not a 12mm maxle.... I have the same setup on my 240s hubs... 10mm rear and 9mm front axles running in usual QR drop outs.
