Road Bike Tyres
JJDT
I need to replace the tyres on my roadbike. I have noticed that there are now different sizes 23c and 25c. What I also noticed sometimes is that the 25c is somewhat cheaper than the 23c.
Question what is the benefit of a 25 over a 23?
  • Replies 47
In short 25c are wider (roughly 25mm wide).
Some have different shapes where they are taller than what they are wide and some are wider than tall...
They provide less rolling resistance than 23c.
Fitted my roadie with the Spez Turbo 26c, noticeable difference over my Conti GP2000's 23c. Ride is plusher, feels faster and I actually feel that I can push them harder through turns. Lean in an go, perfect!
Will definitely stick with the wider tyres. Also very well priced (R470)
Good to get 25c if you've got wider rims as they fill out the profile and you don't have a mushroom effect. Not so beneficial if you're running 14mm internal rims and drop the pressure to 80psi.
Just check your current frame can take wider tyres. For example my 2015 Evo couldn't take 25c so I got a nice set of AMC wheels with 23mm internals, strapped some 23mm Pro One Tubeless and the profile was nice n fat.
Just get one with a cotton side wall, game changer.
They dont last that long though...
Good to get 25c if you've got wider rims as they fallen out the profile and you don't have a mushroom effect. Not so beneficial if you're running 14mm internal rims and drop the pressure to 80psi.
Funny you mention the Schwalbes in 23c on a wider rim... I fitted the 25c Ones and they are a lot fatter than the Fredestein Fortezza Senso 25c I had before. Not sure I like their profile.
Indeed.
If comfort is your aim, an open tubular with high thread-count casing is the clincher answer to riding FMB, Clement or Dugast tubbies.
Add a bit of width, say 25c or even 28c, a latex tube, a bit less pressure and gum-walls, and life gets even better. Better grip, better acceleration, cooler looking and with literally unbelievable (as in "holy 5h!t, i did no know that tires can make such a difference to how my bike rides") ride comfort.
Having said that, I must admit I get more Km/ZAR on a set of Gatorskins????
 "Having said that, I must admit I get more Km/ZAR on a set of Gatorskins" +1 Same here...
Lots on Bike Radar about 23 vs 25 vs 28. If 25C fits your frame, go for it.
Yeah, that is a problem. Idea was to use them for races only, will see how keen I am to take them off after L'Etape.
Why would a 25c have less rolling resistance than 23c?
Seems a bit counter-intuitive to me?
Yes
It hurts my brain
The bigger the contact surface
The less the rolling resistance ????
Something about metric pressure ????
Indeed.
Gatorskins.... eeeeeeeuuuuuuw!!!! I just cant stand the sight of them no matter how good everyone says they are... besides I had more punctures on the set of gatorskins than all the other tyres I had combined.  To me punctures have proven 80% bad luck 20% tyre protection - but that's just me...
http://www.bicyclerollingresistance.com/
Just an example - but it has been proven - something about the shape of the fooprint and size and deflection of the tyre creating the combined rolling resistance.
the worst part is... they now say 28c is even better - especially if you are heavier than average. (which most of us SA gents are)
