Help identify the problem
cadenceblur
Something bent? either that or the BB is loose.
2 tests you can try
- If you take the chainring off and put it on a table you would be able to see if it is flat or not.
- if you wiggle the cranks you'll quickly see if they are loose / BB is loose
Chainring is clearly not running flat. Check that all the chainring bolts are secure. If they are, you may need to gently correct (bend) the chainring outwards.
The other knocking sound I have no idea :)
Good luck
