Cleats for Spinning / Wattbikes
AllAboutRides
Hi all hubbers!
I've recently bought myself a pair of road shoes (triangle cleats underneath shoes) to use in the gym with their spinning and wattbikes.
Which cleats should I fit on them to work on these bikes? I don;t want to change cleats everytime with my MTB shoes as they are LOOK cleats.
As far as I know Shimano SPD pedals are used on gym bikes, but what cleats will I need for my road shoes?
Hope this makes sense to you!
Cheers
  • Replies 34
  On 7/6/2017 at 10:55 AM, Tubehunter said:
I have look keo cleats on my road shoes and these work on the WATT bike fine.
Beware of marginal gains from this when you upload back to STRAVA..... :ph34r:  :whistling:  :thumbup:
What gym are you in and what pedals do they use?
  On 7/6/2017 at 10:49 AM, bertusras said:
You need this: https://www.cyclingexpress.com/en/productdia/7110052/shimano-sh-sm85-cleat-adapter-plate.html
And these: http://www.cwcycles.co.za/product/shimano-sm-sh51-mtb-cleats
Trouble is going to be to find the adaptor. You should have bought MTB shoes, would have been easier to walk in as well.
I have MTB shoes but don't want to change the cleats everytime I go to the gym :-(
Constantia VA. Not sure of the pedals, but the road bike cleat compartment usually has a toe clip structure connected to it, that you have to remove if you want to use the road cleats with the pedals. The other side of the pedal has the mountain bike cleat option.
Makes sense! I will go and check with local VA.
Thanks dude!
As far as I am aware, Wattbike has standardised to the Shimano MTB Cleats/SPDs? I have two sets of shoes. One for my road bike and some MTB cheapies with SPD cleats for the Wattbike.
Most wattbikes at VA will be able to take both road and MTB cleats.... remove the plastic toe loop for those that use takkies and you will see that the pedals have road cleat on one side and MTB SPD on the other..... will look something like this.
MTB cleat on the top, turn the pedal over and will take a road cleat
http://www.trueridestudio.com/wp-content/uploads/2017/01/SPD_PEDAL.jpg
Will go and check a bit later and will take photo's of the pedals :-)
Thanks in advance!!!
Seriously? I need to go check that out!
Just added a pic to help.  All the wattbikes (7 of them) at my VA are like that, but best to check to make sure
Awesome!!! Thanks!!! So what cleat should I use on the road side of the pedal? Shimano SPD ?
