What grease to use?
Demetri
Hi,
Can anyone tell me if i can use Delo Chevron ESI grease to service my bike? Mainly service all bearings, headset,bb cones etc.Or should i just buy finish line Teflon grease? Also where can i get Teflon grease in Cape Town/Worcester?
I like the Finish Line Bicycle Grease (White Grease) because it lasts a long time on the hub bearings specially. (MTB)
I've used normal Castrol wheel bearing grease on the hubs but it seems to last less time, A few rides and it's all gone.
you are supposed to put it on the inside mate :whistling:
You can use any grease that you like, question is if it is fit for purpose...
Grease is a specialist lubricant and designed to lubricate under specific pressures and at specific temperatures. Using high performance industrial grade grease in your bike will not lubricate as a light duty grease will do.
It is advisable to get the best protection and lubrication to use a bike specific grease. However, as I said, you can use any grease, that includes lard, but should you?
As much as i agree with the statement, Bike specific is usually just rebranded something else.
When replacing grease in bike try using grease that conforms to the same type/specifications.
Wheel bearing grease is usually fine for your bearings of all kinds on a bicycle.
Good and straight forward answer. I'm replacing all my bearings on my hardtail. Headset, BB, Hubs etc. Jockey also getting a good overhaul and new gear cables. I have a tub of Castrol WB grease and Chevron grease just sitting in the garage. Just not sure if i can use these grease and why not.
HA HA Funny Comment.
Of course it goes on the inside. On the Cups Balls and Cones.
The slimy black/brown cheap stuff just does not last as long.
I'd rather pay 3 times the price for 1/5 the grease and get the good stuff.post-119568-0-62191800-1515587964_thumb.jpg
You can use WB grease on your bike, ESI is a medium to severe duty extended service interval product, nothing on a bike can stress it beyond the intended use specification. If it is an old tub/container of grease go through the extra trouble of mixing it thoroughly. Grease is a semi-solid lubricant, over time the oil and the soap (emulsifier) does separate. Giving it a proper mix will ensure you get a balanced product which has not separated yet. I am being pedantic.....
