Tools for bike build
Pieter1
Hi hubbers.
I’m busy getting together parts for a build and for the first time I can not rely on a bikeshop to put it together for me. At this point in time I own a hammer, a screw driver and a shifting spanner. What tools will I need to put these parts on the frame? Will a set of Allen keys do the job?
  • Replies 80
BB tool
Cassette tool
Chain whip
Allen keys will do almost everything, except you need a hex for the rotor bolts. Also if you cutting/shortening the hoses of the brakes you'll need a bleed kit
What Meezo said and -
* Pliers for cutting outer cable housing.
* Torque wrench (if you want to do it properly).
* You might need a T25 and/or a T30 Torx Wrench.
* Hanger alignment tool (might not it but can save you struggling to set gears).
* Pliers :eek: for cutting outer cable housing.
i think you mean a cable cutter  ^_^
feed an old cable through where you need to cut and a good set of side cutters do the job :ph34r:
BB tool
Cassette tool
Chain whip
Agreed
One can get away with the most  basic of tools. If you use your head.
Chain breaker.
Hacksaw, good PLIERS for cutting cables and housing. Cheap Chinese pliers are rubbish.
Hex set and a few torx drivers.
A normal 10 cc syringe without the plunger can be screwed into the filler hole of most brakes. And use a clear piece of flexible plastic pipe to bleed the brakes.
Ah okay. Cool thanks guys. What grease should I get? Also had a look on amazon for a torque wrench. Are all created equal or should I bite the bullet and get a park tool one?
Computer, modem, internet access - essential if you haven't done it before. Doing things in the right order and in the right way will make it a lot easier. Watch this, a Giant Anthem build, but you can also find many others that will show road and old classic builds.
