Rockshox charger damper - failed
lone one
Rockshox charger 2 damper RC has stopped working
Fork was stuck mid compression and would only use about 20% of the stroke
Removed the damper and eventually got it to compress - this resulted in oil coming out through a nick in the damper bladder
I have searched the web and found nothing
Question - anyone else experienced this issue
It is sealed diaphragm with the bladder holding the oil - it is sealed in the station so how the nick in the bladder it a mystery
Rockshox is obviously saying the entire damper needs to be replaced
Age and service history?
damper is 2018/2019 - lower leg service and air regular service. I was advised that the damper due to it been a sealed unit it not needing service
So that's at least two years of riding with the same oil in the damper? Eish.
You might need to look for better advisors.
Fork is on a bike bought second hand. As the charger 2 damper is a sealed unit what I have also read seems the oil is not a service item
Your views?
Every 150 to 200 hours for a damper. If you ride lots that's twice a year...
Lowers every 50 hours.
There is no fork that does not need a damper service.
Yeah, riding a damper for 2 years without servicing will do that. But Rockshox's spare parts selection is a joke, that's something that should be readily available.
I might be able to source replacement bladders, give me a shout on the 11th and I'll confirm.
Your views?
The whole damper is serviceable including the oil.
Charger Damper has a 200hr service interval and the bladders are replaced during this service.
Who is advising you?
Another RS parts fail.
I have a 2014/15 Pike with the Original Charger damper. It blew the bladder a year or two back after a run down a stair set and sent the damping oil into the leg where it sloshed around noisily. Droo was able to source the kit with damper bladder and its still going strong.
