When I switch it on the battery status says 99%. 25mins into my ride, it drops to 3% and then dies. I reckon I need a new battery. Has anyone done a battery replacement recently? Any help/advice will be appreciated.
Hi, send this or personally book it in at Garmin in Rosebank (JHBG) and they will upgrade you to the next model up. A small balance is what you will pay. You will be better off than spending money on a new battery.
26 minutes ago, fanievb said:
what @TCTG said.
send it to garmin, pay R1700 and you get a brand new unit.
the only way to get a battery is to order from the likes of amazon
When last did you get a replacement unit? Not sure its R1,7K anymore, suspect it will be more expensive...
Not entirely sure the replacement route is worth it anymore.
Batteries are available ... R200-R300 from what I've seen.
Some are replaced by simply unplugging while others may need cutting and reconnecting of a cable or two.
Check the You Tube videos for the 500 unit.
4 minutes ago, Titleist said:
They don’t give a newer model. They replace like for like.
They do give a newer model if the one going in has been discontinued such as the 500 in this case. I sent a 500 in and received a 520 in return. This was in 2018, so now it will probably be the 530.
1 minute ago, Titleist said:
I called them a few weeks ago to enquire about an 820 and they said you get the same model that you hand in.
They replaced my Garmin 500 with a Garmin 520 few years back, the 500 has been discontinued ages ago.
I suspect the OP will have to pay quite a bit more than the R1,7K mentioned earlier to get the current equivalent model at a "factory price"
If he is still happy with the Garmin 500 I would suggest going for the replacement battery via the internet and youtube instructions (that Thomo suggested)
Some info received from Garmin:
Unit is discontinued, they do not replace batteries for any of the Edge units.
Unit can be booked in and sent to Garmin SA for a discounted quote on a replacement unit.
I asked Garmin for a ballpark figure, and they said I can expect a discount of about 20-30% off the new retail price as per Garmin. However for an official quote the unit needs to be booked in.
In principal its really daft that something stupid like a flat battery means the end of your Garmin, really a battery is something that one should be able to replace.
I would assume that getting a replacement battery locally  would be a mission. For example the battery replacement kit mentioned in the previous post, the company does not ship to South Africa. Also, (I may be wrong about this), I think that shipping companies are not allowed to send batteries by airfreight anymore. I would rather browse the classifieds section, there was a number of Edge 500s up for sale at very reasonable prices. I purchased mine here of the Hub's classified section a number of years ago, and it's still going strong with really good battery life.
Another option would be to see if you cannot hack a battery intended for a cell-phone, and with a bit of soldering you may just come right.
Edited by Jaco Steyn
Ohhh, I didn't realise they don't ship to SA. Scrap that idea then.
