its mainly because i found a 2nd hand groupset and because my bicycle gears/brakes stopped working first my brother got the chain off the casette. then after putting it back it never sounded the same. i got the bicycle full of mud then i sprayed it off. after that the brakes and gears stopped working
Edited by Pieter De Klerk
It wil work, just a heads up if you replace the brakes, if the hoses was cut or too short it will require a bleed. gears will work.
