 HI all
the guys at the bike shop said that i could clean my whole bike with paraffin, shock, frame , chain etc. I have a basic HT with deore parts. Should i clean with paraffin or not.
No need to go that extreme. Just do the cassette, derailleurs and crank blades. The rest of the bike you use car shampoo or even, bit my tongue, sunlight liquid.
I use Cleangreen on the cassettes and frame to clean it and some spray on stuff to make it shine afterwoodssmileys/smiley4.gif
Marius38918.617037037
  Quote
what some other guy had to say:" Are disks better than V-brakes? The answer: it depends on you. I've been using V-brakes' date=' Kool-stop pads on ceramic rims, and found them to be more than adequate for my type of riding. I've used XT disks on a friend's bike, and found that I disliked the fact that the lever throw was very short, and that almost all the power came on almost at once. I'll probably need 4 or 5 rides to get used to the reduced modulation, an investment of time that I won't make because:
V-brakes are good enough for the feeble type of cross-country riding that I do;
V-brakes are lighter;
V-brakes are less complex, thus easier to set up and maintain (no annoying rotor rub);
V-brakes are cheaper. "
I agreeClick on image to open in new window[/quote']
en dit het wat met die thread te doen?
IMO NO!
Paraffin has reasonable cleaning, lubrication and excellent penetrant properties. As a result it will get into the smallest space and any surface coming in contact with it will exhibit a slightly oily residue , which in turn will attract dust if not cleaned off properly.
Not ideal for painted surfaces, non metallic material or repeated contact with human beings.
Would not recommend it to be used to clean the chain if you use a dry or wax chain type lube.
I use paraffin to clean the cassette, derailleurs and chain. Works well!
Frame I use McGreggors shampoo... and then after wards I use a touch of turps on the brake levers, cranks and brake calipers just to give them that nice shine... before I used dog shampoo and smelling like wet dog for 100km's + did not work to well... Click on image to open in new window umm that was just a joke? Click on image to open in new window
As for lubing the chain... Chaintech works well... smileys/smiley2.gifJason38918.6375462963
Agree with Jason.  Logically you use paraffin to degrease your chain, etc.  If you should use it on a shock, etc and some of it gets past the shock seals you'll be stuffed!!!
I use engine degreaser for my MTB chain and one of those rolling thingys for my road bikes.  Rest of the bike I use Sunlight Liq and afterwards some Mr Min.
  Quote
You suppose to wax ur legs not the bike . How do u wax ur bike ?
Ja, jou aap......maar ek wax nie my bene nie so ek moet iets wax. Maak nog sulke grappies en ek wax sommer jou kop! smileys/smiley36.gif
  Quote
  Quote
Ja' date=' jou aap......maar ek wax nie my bene nie so ek moet iets wax. Maak nog sulke grappies en ek wax sommer jou kop! Click on image to open in new window
Sy hare is te kort vir wax, try eerder 'n tweaser!
  Quote
  Quote
...try eerder 'n tweaser!
tweaser for wax or someting else? hehe Click on image to open in new window or both Click on image to open in new window[/quote']
Sjeez Jason, for the hair on his head jong!!!  Yuck, SOMTHING else (no where is that smiley of the okey hurling at the screen!!!!!)
  • 13 years later...
So after cleaning your chain with paraffin, do you just wipe it clean with a rag or do you have to rinse it with water and then dry with a rag? Just wondering if after cleaning with a degreaser or paraffin and some of it stays in the chain will it not displace the lube afterwards.
Edited by Slumiesboi
