  • Replies 48
quick question ... Shimano Cassettes hg 50 R350.00 ....SLX hg 80 R499.00 which one?
What free hub body ... a nice solid steel one or a light weight aluminium one?
I'm sitting with same issue.
I have a set of Easton Havens as well as a set of AM Classic MTB.
CWC doesn't have 36-11 in SLX so either I wait (for undisclosed time) or I opt for the Deore instead.
Not THAT much of weight penalty, but I was wondering how about durability? I know the SLX's last looooonnnnngggg.
http://bikescale.com...mar=14&sk=1&s=3
RANT ON
I don't understand when someone asks a question and obviously has a budget, why you would recommend something that is obviously not in budget...
RANT OFF
SLX is fantastic MIKE.
If you plan on getting a new GS after every dirty ride get XTR . The more expensive the GS gets the lighter and less durable they are . So Deore will last you a very ,very long time while XTR will not . Simple .
I usually check buycycle in addition to cwc, looks like they doing the Deore for R306 (cheaper) but the SLX for R650 odd (more expensive).
My issue I bought a slx groupset, but they didn't have cassettes in 36-11 in stock when I ordered.
They sent my whole parcel without the cassette saying they will do so when the next shipment arrives.
Now the shipment arrived & they didn't receive 36-11 cassettes.
I heard the larger gears on the SLX are the same compund as XT & the smaller gears are the same compound as the deore. There is a colour difference in SLX (smaller gears) & the deore though. :blink:
Anyone know whether that info is true?
Then Deore should last as long as slx, but if you use your big gears very often then it might even outlast the SLX in that regard.
I have solid steel cluster, moer heavy, but almost not a sign of wear. Aluminium will wear out quicker, but much lighter.
BTW, Think I have a Sram cluster with my XT derailleur, which can also be an option
You last statement is true . Never looked at the colour , mine goes black for some reason .
