Road bike punctures
Belgarath
Hi guys
I did a quick search, but couldn't find anything specific to my problem.
I'm a roadie noob. I'm borrowing a road bike for 94.7. I've had four punctures in the last four rides. It's rather irritating.
Can any roadie supply some tips/tricks of the trade so that I can actually finish rides? Normally, we mtb'ers have big, chunky, tubeless tyres filled with sealant, so punctures don't actually happen.
I do have a puncture repair kit, as well as a spare tube riding along, but trying to wrench these wire-beaded Vredesteins off the rim, trying to find the blasted hole, patching it, and only then re-engage the wrestling match to get the tyre back on, while cars are whizzing past, is not exactly fun. :cursing: My riding buddy (also actually a mtb'er) tried sealant in his. The sealant came out so fast with the high tyre pressure, that he got coated from shoes to helmet. There is also not enough air in the tube so that the sealant can do its job.
This afternoon I'm training on my mtb again...
  • Replies 37
Get new tyres
Be vigilant on the route for sharp objects
At coffee stop, check tyres for any stuck objects
After ride, check tyres again
Use super glue to fill any small cuts or abrasions in rubber
Run pressure less than maybe 7.5 bars (I weigh 69-70 and run at 6.5 bars) as this minimizes pinch punctures.
Take the bike into a bike shop and get them to check the tyre liner on the wheel, sometimes this kinda wears out and gets sucked into the holes and can cause a puncture. Check the inside of the tyre to make sure that there's no glass or anything along those lines which keeps puncturing the tube. Make sure you don't pinch the tube by mistake when putting it back on. I had that issue previously where almost every ride I was getting a puncture so I took my wheel in and they changed my tyre lining and not a single puncture since then.
what type of punctures are you getting? Are you sure that whats causing the punctures are removed from the tyre before putting in a new tube?
What kind of punctures are you getting? Cuts, thorns, or pinch flats?
There could  be something stuck in the tire. I had a metal filament once, so fine not easy to detect, got 5 punctures before I found it.
I run at 6 bar front and 7 rear with no issues and a nice comfortable ride.
A simple process of elimination (and a bit of cash) will sort it out.
Remove the tyres and tubes
Check the rim tape. If it is old, brittle, or damaged in any way, replace it.
Check the tube. If it has lots of patches, replace it. Check the valve too.
Check the inside of the tyre. Anything sharp stuck in there? Remove it
Check the outside of the tyre. If worn, replace it. If small cuts, clean and superglue them.
Reassemble. Pump to correct pressure, normally around 8 bar is a good starting point.
Problem solved.
Just a question, are you running tire liners by any chance? The kind that goes between the tube and the inside of the tire.
If so, throw them away, the overlap causes pinch flats on the tube.
Do yourself a favour and put 700 x 23/25c Conti Gatorskins on, you will almost never have to deal with a flat wheel again.
Watch out for those repeat punctures, as been mentioned, when one does not clean / clear the tyre area properly before replacing a tube.
All causes were found and dealt with (sworn at and thrown into the bush). Noob roadie, not noob cyclist :-) 1 cut, 1 metal filament, 2 thorns.
Repair tubes once maybe twice max, throw them away then. Their must be something inside the tyre that is causing it. Check for glass pieces that is in between the rubber also.
This must be your bad luck then.
