Shifter cables - going price?
Uni
what's the going rate for the shifter cables - i looked at some of the online places and I only found kits - just need the inside cable thing - little DIY project for the weekend just wanna know if i'm being ripped a new one or not.
  • Replies 40
Cable in the region of R30 p/m housing about R70 p/m.
:eek: My prices must be cheap then...
I charge R22 for the cable and R30 per meter for housing.  All Shimano stainless cables with Shimano housing.
Replace the housing while you at it, also available at the workshop by the metre. Ask for the cable housing ends to!
but I only learned how to do the cable :blush:   - how hard is it to do the housing too?  :eek:
Depend on quality and material type.
Inner Cables rough guide:
Mild Steel ±R15 (the stuff that comes on kids bikes, complete $h!t)
Semi Stainless ±R25
Full Stainless ±R35
Teflon ±R50
Gore/ Shimano Dura-Ace ±R120
When the cables are out remove the old housings, measure the length on the new housing, cut new housing, add housing ends and re-fit. Then just fit new cable.
Proper cutters to do the housing helps!! I did mine with wire cutters which are not the easiest but you can get it to work (if you really have to!).
Not difficult at all.
An essential tool though is a decent quality cable cutter. You want to have a nice and clean cut when you're installing the new outer and snipping the end of the inner.
Just make sure to buy the correct length outer - use your current one as a guide.
+1 on propper cutters. Don't underestimate the cable housing!  Improper cutters can sort of clamp the housing  which causes some cable friction. You can pry the housing open again with some fine screwdrivers and a plier, but it's less than ideal.
so where do we find you?
