12 Speed Up Grade with XT Crank
Sidmouth
  • Replies 32
  On 4/5/2017 at 6:54 PM, V12man said:
I counted on the picture... 34..
  On 2/16/2017 at 1:15 PM, ØÐINSȪƝ said:
If you run ANYTHING smaller than a 36T chainring with an Eagle setup, please sell your bike and take up lawn bowls.
still less than the amazing thirty sixxxxxx  :whistling:
Her name is not Jaroslav...
Jaro was also riding a 34.
  On 2/16/2017 at 1:48 PM, splat said:
This is the CRM80 vs 81 (old vs new) comparison
I was going to say the original design of the 11spd Shimano rings would be questionable for compatibility, the tooth profiles were very square compared to normal narrow wide rings.
  On 2/16/2017 at 12:34 PM, Sidmouth said:
Thinking of dong the Eagle route, anyone know if you can get a 34T 12 speed chaining that will fit a XT crank, hoping to save a few bucks by avoiding a new crank
If you are budget sensitive you should not go 12 speed at all .An 11 speed works just as well and you can buy a shimano 11 speed conversion for much less than eagle .I am currently on Shimano 11 speed 34 x 11/46 .I don,t feel i need any more gears than this setup .Rapide/sunrace 11 speed cassettes are 25% the price of a 12 speed one
When chains cost R900 and the cassette costs more than an XT upgrade kit, you cant possibly put 'Sram Eagle' and 'Budget Sensitive' in the same sentence.
http://www.cwcycles.co.za/products?text=eagle&items_per_page=16
I went for the 36 on eagle as I was on 32 on XX1 before. When you compare gear ratios, it was very similar, so the legs didnt need to adjust to a new rhythm. My granny on the eagle is also lighter than it was on the XX1 - it compares to about a 30t front ring on the 42 of the XX1.
There is quite a few aftermarket options which will fit your XT crank, so yes it is possible. Have a look at absolute black.
  • 3 weeks later...
Correct, the Shimano 11 speed chaining will not work, it has to be a Narrow Wide Chainring, there are many aftermarket brands avalible
Jaro rode 38T in that one race last year right ?
Stupid move to gain some publicity  :rolleyes:
They rode bigger rings during the prologue than the actual race apparently - guess they pre rode the prologue course to find a good setup for the long downhill that also let them climb ok.
Are we talking about the Epic or XCO ? Because I was referring tho the latter
For the epic- for xco they pick ratios dependant on the course. Jaro is a machine - there is a video of him testing the Brazil Olympic course showing power numbers... whole periods of 450w plus and even more from time to time - really impressive power
  • 6 months later...
