Hi guys
I have a 2016 Giant TCX SLR 2 gravel bike using TRP Spyre-C mechanical disc brakes.  I have upgraded my rotors from Tektro 140mm to Shimano RT66 160mm front and back.  Braking performance is however still extremely disappointing.  Do you guys have any affordable options without having to change my Shimano ST5800 105 shifters?
From some research my main options looks to be the following
SwissStop Organic brake pads
Compressionless brake cable housing
TRP HY/RD mechanical/hydraulic calipers
Would appreciate any advise
I use mechanical calipers (some generic ones) on my 'MonsterCross' bike and even though I would concede they do not feel great (spongy) they have no lack of braking power. Tested them just last week when an errant driver wondered across into the emergency lane suddenly .... locked the back wheel on tar!
They do however need to be setup with as little tolerance as possible and that the wheel still spins freely ... also try to check it every so often.
Anyway that's my experience and on 160mm rotors BTW
Have only felt cable disc brakes on MTB and have to agree with Simon123 that they suck. There's the pricey Hope mechanical to hydraulic "adaptor" , or TRP or Shimano hydraulic levers, that would be the best option IMHO
the whole point of going to discs is to improve braking, and as it has been proven with MTB's it doesn't seem possible to make cable disc brakes with comparable performance to hydraulics.
so IMO, if you don't go hydraulic discs its best to stick to caliper brakes.
The Spyre mechanical disc brakes are apparently the best cable disc brakes to be had. I have them on my Defy, and also was not that impressed.
But... try sanding the pads a bit (sand paper on flat surface) and cleaning the rotors thoroughly with alcohol.
Further improvements for me were had from new rotors (icetech up front) and lately I'm running metallic Shimano pads up front as well - got wet a few times and the noise from the organics!!!
Don't both upgrading the shifters. Pads and rotors is all you need.
I think the brakes come with Tektro brake pads, a brand I don't really trust.  Should I look for a Shimano option? Organic vs sintered?
Think I will give this a go and then maybe later look at a mechanical/hydraulic hybrid option if there is no improvement
Build my first gravel "monster bike" with Sora shifters and Sora (STI specific entry level CX) mechanical disc callipers.
Braking was okay
Did a few upgrades on the build of which one was Sram Red 10 shifters.
Because the Sram Red shifters are carbon and supper stiff braking performance improved drastically.
Was really amazed on what difference a brake lever could do with the same calliper  / rotor
But guess that is not the answer you looking for :blush:
heard some people are using these CNC aluminium cable brake housings and say it also improves braking on cable brakes.
Edited by Mongoose!
Where can one order compression-less brake cable housing, seems hard to find locally
Each time I do a search, Jagwire pops up. Wiggle and CRC are good bet. Locally? Who knows?
Hi guys
Buy these:
https://www.bikehub.co.za/classifieds/243042-brakes/
Or these:
https://www.bikehub.co.za/classifieds/245208-complete-groupsets/
Or work through the process of changing the housing, then the pads, then the cable, then the callipers and finally add hydraulic fluid with all the changes that entails to all the above plus the levers.
Jagwire is as floppy as a 70 year old's pork sword without Viagra.
Zero chill. But good to know your frame of reference, as disturbing as it is. [emoji16] [emoji3]
Sent from my SM-G920F using Tapatalk
