I am looking for a welder in JHB to fix my titanium frame
I FLY
My Lynskey frame has cracked and the Lynskey agent is battling to find someone in Johannesburg who knows how to weld titanium
I am the 2nd owner so no warranty.
Ti is difficult to weld correctly.
Why is the agent involved? If it is a warranty, rather get a new frame.
Because if you read the OP properly he clearly states he is the 2nd owner.
Just saying
Ti is NOT difficult to weld if you are a competent tig welder - no more difficult than aluminum to tig providing you have the correct equipment and shielding gas, and a way to shield it properly.
A bit of a highjack.
I also own a Lynskey (2nd owner too) and the frame has some scratches that I would like to get brushed out.  Any recommendations?
Thx!!
If you can find the original grit it was done with, it's easy to do - just find cloth backed sandpaper strips and do it yourself - hint - cut up a beltsander belt of the right grit..... and go gently.
Thx!!
take one of those green and yellow pot scrubbers to it. should brush up fine.
That is the trick, I don't want to mess up the frame by starting with the wrong grit!!!
No idea how to find the correct grit.
