Firmware Update - Powertap G3 ANT+
mecheng89
Afternoon Hubbers!
To those who own or have owned a Powertap wheelset, specifically the G3 ANT+ model, how does one do a software update?
I have downloaded, just for the sake of the update, Poweragent. Then I remove the G3 cap from my rear wheel, which has a mini-USB port. I don't know what kind of cable to use to connect to my PC? I used several cellphone charger cables but the computer does not recognise it.
Thanks!!
Quick Google search:
https://www.powertap.com/support/faqs/hubs-wheels
Video instructions are available
  • Spin the wheel/axle a couple times with the Powercap still on to "wake up" the Powercap
  • Take Powercap off by removing the triangular nut and pulling Powercap straight off (do NOT twist)
  • Remove the CR2032 battery from the Powercap
  • Plug the Powercap without the battery into your computer using a micro USB cable
  • Open PowerAgent
  • Navigate to Tools > Firmware > Check for Firmware Update
  • Click OK to begin the firmware update
  • Firmware will install. With some new versions of firmware, Window OS will need to “re-find” the attached PowerCap. Let it run to completion.
  • When PowerAgent says the update was successful, click OK and unplug Powercap
  • Wait 10 seconds, plug battery back into the Powercap
  • Install PowerCap back on PowerTap hub
Afternoon Hubbers!
Thanks!!
Try Bluetooth as well via the mobile phone app.
  • Open PowerAgent
The above video is correct however if running an ANT+ / BLE (dual) power cap please see below.
https://www.powertap.com/support/firmware-history
You will either use Rouvy or the PowerTap app to update the power cap via BLE.
Any issues please call us on 011-023-2777
  • 2 years later...
hello
I have a problem with my powertap G3. I can not make an update because of my diferent plug in. If you have ideas please help me.
Thank you
Silviu
sorry for my english I'm french.
  • 1 month later...
hello
Thank you
Silviu
That might be the dual ANT+/bluetooth version that can update via bluetooth?
Yip have the same and was also baffled with the connector.
The firmware can be updated using BT and the powertap app
