Next XTR: It is 12 speed !
Christie
Advantages of 1x vs 2x system
Improved Ground Clearance due to smaller chain ring.
Improved Chain Retention and Much Smoother pedaling action due to the NW chain ring (Longer Teeth) and Precision CNC Manufacture.
Less Chain Noise and Improved Chain Line. Chain dropping eliminated.
Eliminates 5 adjustments L H Height Tension Parallelism.
All Gears Usable. Cleaner Cockpit Layout and Lighter Bike.
Max Speed of 30-36 Km/hr Achievable dependent on Chain Ring Tooth Count. 29er.
Min Speed of 6-9 Km/Hr Achievable depending on Chain Ring/Cassette Combination.
Tuneable - Front Chain Ring can be changed in minutes and are freely available.(Reasonably Priced)
Chain can be easily removed from crank for cleaning and maintenance. (Chain stays cleaner, the NW ring seems to eject dirt from the chain.)
Cheaper to maintain bike due to reduced parts count. Even wear on cassette because you now use all the gears.
No speed loss when you change from big ring to small ring on a 2x.
But the best Advantage is the way it rides, the close ratios are a big +, You find yourself improving and being able to tackle more difficult situations with ease.
  • Replies 236
By dominated I refer to the stats on the total number of competitors that were riding 1x systems. Something like 80% if I recall.
The 42to 50jump isn't big if you using it when required. On a flat road Yes it's a big jump but then why would you need it on anything below 15% gradient? Train harder maybe?
because some people run a 36t
many riders that are on 1x11 sit in the last 4 gears of the cassette anyway
If a manufacturer really wants to corner the market they need to create A cassette where every single cog is separate and can be purchased separate , this will be very confusing to keep track of but that is really something that will make an impact imo
Guessing it’s a new Scalpel as well as the new Shimano Groupset!
gotta love that eagle looking decal , hint hint sram ..... the japs are coming
That’s the German National Animal symbol - he’s German. But I guess we could say that [emoji23]
I think you're looking for your porn in the wrong places. Lots of excellent free stuff out there.
IMO its all about your weight and fitness.
Summary of my reply is i went back to 2 x and am happy again.
WRT XTR: XTR is and always has been made of unobtanium thats why its so pornographically expensive. Its like running carbon fibre discs on a Porsche road car  - great if you are a racing driver but useless if you do 20 000 km in your road car every year.
12 speed XTR is going to have an inhale factor that is going to leave us all breathless when we see the price. Do i like it - yes. Do i love it - yes. Do i need it - no. Will my 2 x 11 speed make me happier - yes.
FWIW: My lesson wrt this was using 10 speed road bike groups mixed with MTB groups. I managed to build a combo for my wife's bike using Ultegra compact cranks, MTB RD and clusters and road shifters that has all the climbing range and low ratios and all the high speed pedalling range - more than my 2 x 11 does. And for a third of the price using spares i bought here.
1 x is really like half of everything. IMO designed for people who can cope with it. Its like designer fashion gear: it only fits super models with insane body measurements and the balance of the populace who are normal aspire to being like them but can never quite get there.
Still 2 levers on the LHS of the bars... vs 1 on a 1x
And then you do that on a Scott Spark with the lekker lockout levers, and then you hear about these dropper post things. And then you mount your light nexto your Garmin so you can go for a night ride. And then 900mm bar widths become the new benchmark.
apparently it is a "thing"
http://i.dailymail.co.uk/i/pix/2014/08/05/article-2716329-203E16BD00000578-112_306x685.jpg
With those pants design, he must be.......
An Enduro rider
