Will X0 10 speed carbon crank work on Gx 12 speed setup?
Johnny 55
It will work, however, I would recommend changing the chain ring.
The 10 speed chainring isn't a narrow wide version, meaning you would likely experience some dropped chains.
Hi guys, im thinking of replacing my Gx 12 speed crank with a X0 10 speed carbon crank. Will the X0 fit? I cant see why not. Thanks.
Many things to consider
Like is the spindle gxp,bb30,dub ?
Bcd or direct mount compatibility ?
Crank arm length ?
Photos will be a good start
Then you're winning. Millions of options for a direct mount 12 speed NW ring, just make sure you get the right offset for your frame.
I installed a 2012 SRAM XO crank to my 2018 Scott Spark, just fitted a 3mm offset Absolute Black direct mount chainring and works like a charm.
If GXP then just remove the 4 bolt spider and fit a 6mm offset Xsync Direct Mount chain-ring for a std 142mm x 12mm rear axle setup or
3mm offset Xsync Direct Mount chain-ring for Boost set up.
Where you may run into a problem is the Q factor. IS your crank a Q156 or Q168?
IF Q168 then you are good to go.
