colindavie86 Posted March 4, 2019 Share Hi HubbersI been looking at building up a 29er steely for the local trails. I have come across a Niner MCR9 frame. Want to know your opinions on this frame? Does anyone know if I can run a tapered fork? Whats the geometry like for trail riding/ climbing?Thanks Link to comment Share on other sites More sharing options...
Eddy Gordo Posted March 4, 2019 Share Have a look here https://www.bike198.com/review-niner-m-c-r-9-29er-geared/ Link to comment Share on other sites More sharing options...
Me rida my bicycle Posted March 4, 2019 Share That's a terrible frame I will come pick it up to save you the trip of dumping it???????? Andrew Steer, the nerd, Brick_Top and 1 other 4 Link to comment Share on other sites More sharing options...
Me rida my bicycle Posted March 4, 2019 Share Can't go wrong with 853 Reynolds and that's probably my favorite Niner frame. Link to comment Share on other sites More sharing options...
Eldron Posted March 4, 2019 Share Those Niners made with Reynolds 853 tubing are fantastic! I've owned, ridden and loved more than a few :-) Theyre designed for straight forks but an external bearing adaptor for the bottom will allow a tapered fork (but slacken the head angle around 1 degree. Edited March 4, 2019 by Eldron Hairy, DieselnDust, the nerd and 1 other 4 Link to comment Share on other sites More sharing options...
colindavie86 Posted March 5, 2019 Share That's a terrible frame I will come pick it up to save you the trip of dumping it Link to comment Share on other sites More sharing options...
colindavie86 Posted March 5, 2019 Share Thanks guysAnd to throw a curve ball what about a rigid fork, drop bars and some long gears as a comfortable road/gravel bike? Allrounder, Swany05 and the nerd 3 Link to comment Share on other sites More sharing options...
Eldron Posted March 5, 2019 Share Thanks guysAnd to throw a curve ball what about a rigid fork, drop bars and some long gears as a comfortable road/gravel bike?Do it. That thin gauge 853 tubing is nice and forgiving. Swany05 1 Link to comment Share on other sites More sharing options...
V12man Posted March 5, 2019 Share Thanks guysAnd to throw a curve ball what about a rigid fork, drop bars and some long gears as a comfortable road/gravel bike?What about converting it to a belt drive.... there are a few posted on the hub and the frame conversions are done by a hubber... the nerd 1 Link to comment Share on other sites More sharing options...
Eldron Posted March 5, 2019 Share What about converting it to a belt drive.... there are a few posted on the hub and the frame conversions are done by a hubber...Cutting up a perfectly functional frame makes my heart sore! Link to comment Share on other sites More sharing options...
V12man Posted March 5, 2019 Share Cutting up a perfectly functional frame makes my heart sore!It's not cutting it up - just some re-engineering of the frame.... you can hardly see the bolted joint after repainting. Link to comment Share on other sites More sharing options...
Hairy Posted March 5, 2019 Share is a belt drive really worth it in the long run .... and if I recall correctly they then also introduce friction into the system vs what a conventional chain system would...... if memory serves, the Sherifffff once outlines his experience with the two drive trains and noted the chain system to "feel" more efficient and smooth.What about converting it to a belt drive.... there are a few posted on the hub and the frame conversions are done by a hubber... Link to comment Share on other sites More sharing options...
Allrounder Posted March 5, 2019 Share Thanks guysAnd to throw a curve ball what about a rigid fork, drop bars and some long gears as a comfortable road/gravel bike?That is what I have done with my chromo Contraband frame. Best bike I have ever owned. I will only swap the frame out for a reynolds when I see one in the classifieds PhilipV 1 Link to comment Share on other sites More sharing options...
V12man Posted March 5, 2019 Share is a belt drive really worth it in the long run .... and if I recall correctly they then also introduce friction into the system vs what a conventional chain system would...... if memory serves, the Sherifffff once outlines his experience with the two drive trains and noted the chain system to "feel" more efficient and smooth.I don't know - I do know he still rides the belt drive.... Dips also loved his belt drive Niner. Hairy 1 Link to comment Share on other sites More sharing options...
Jewbacca Posted March 5, 2019 Share I'm not 100% sure you can run a tapered fork on there even with an external bearing. I'm pretty (but not certain) sure the MCR was stopped before a 44mm head tupe was introduced. IMHO if you're going to go the 29er to gravel route, get a 26er (440mm) rigid fork. It pulls the Geo more in line and stops the bike from looking tall. Eldron 1 Link to comment Share on other sites More sharing options...
Eldron Posted March 5, 2019 Share It's not cutting it up - just some re-engineering of the frame.... you can hardly see the bolted joint after repainting. Visually it was fine but I hated bending open the frame to get the belt through - 853 is pretty thin. Sure it was cool project but it seemed completely unnecessary given that there are a number of steel frames available that are designed to work with belt systems. DieselnDust 1 Link to comment Share on other sites More sharing options...
Register a new accountSign in
