What DOT 5.1 fluid? - Sram Level TL brakes
Mongoose!
I want to install a new Sram Level TL rear brake system on my bike - (calliper hose and lever all brand new -never had any fluid)
What fluid do I use?
Can I just go to Midas and buy any Dot 5.1 brake fluid? Does brand matters? Some labels state something about silicon…?
Or should I look for a cycling specific fluid?
Already have two screw in injections / nozzles gadgets as required for bleeding and….. Youtube. :ph34r:
Would really like to try it myself.
Go to Midas and buy the smallest pack size available of any dot5.1 brake fluid
This!
As mentioned, try buy the smallest amount possible - you need very little and the fluid doesn't keep particularly well.
But do you have the "Bleeding Edge" adapter for the caliper end? Or are those old stock "pre-2017" Levels?
OP - Midas won't have 5.1, you'll need to go to a motorbike shop.
But as mentioned before, 5.1 is 5.1, you don't need the SRAM stuff.
If your caliper is the bleeding edge type you will have the one on the left
and here are the tools, if you have the caliper on the left you need the tool in the middle
