Building Single Speed Wheel
pieterrossouw03
Why do you want to go with a single speed specific hub?
There are single speed kits available with spacers and cogs to convert a normal hub to single speed use.
I got my parts from Rapidé to do this.
Build with a normal hub and use spacers - much more versatile and easier to sell afterwards
This, but if you use a narrow cog, it may dig into a soft aluminium freewheel as there isn't a cassette to spread the load. Hope make a harder, steel (I think) freewheel which solves the problem, go for that or get a cog with a broad base.
What they say above is true...
But Ive always loved my SS specific wheels.. they just better.
But this all depends, I only have SS bikes, have no intention of putting gears on anything, ever.
This is a consideration as well.
Use good quality SS cogs...
Rapide do a well priced SS wide based cog.
Who/what do you use please?
SS specific everything is better if you going to ride a lot .I have a firefly hub and cogs .The hub is closer to a super boost hub .I use BMX chains only
Hope do a SS specific hub as well.
A dedicated SS hub will be way better than a standard and adaptor, both in terms of durability - better bracing angle, stronger ratchet system, and proper interface between sprocket and driver.
