SLX 3x crank on Boost wheel
DR ◣◢
Hi all
Building up a bike soon with a Boost rear end and I'm moving the bulk of my parts from the old bike. Currently running 1x on the crank with a 32t sitting in the middle position of the crank.
My understanding is that a Boost crank spaces the chainring out by 3mm. If the spider is 3mm thick can I just move the chainring outward?
I don't mind buying new cranks and a BB but if I can save R2k on the build then I'm smiling.
ultimately yopu just want your chainline to be as straight as possible, how you achieve that "safely" you should be good, i wouldnt space between the crank and chainring though, but moving out outward of the mounting holes should be cool
  • 3 weeks later...
Hi all
Depending on what BB you have, you can also consider putting in the second spacer which you normally get in the box.
A bit of trial and error but you should manage.
Good luck.
I am in two minds over my HT hanging on the garage wall. It has a old 3x10 setup which gives me plenty speed when riding on tar and gravel.
My Full-sus has a 1x12 setup, so am not particularly wanting to go that route as it's rather slow. I am struggling to find a proper chain ring setup myself to replace the existing rings and cassette that are worn out, or perhaps go with the 2x11 I took of the full-sus and pop that on the HT? That derailler took a knock and is somewhat bent.
Not to derail the discussion but just a quick note re this.
I used my 3x HT also for the above reasons, so when venturing into the 1x / 2x world (only last weekend!) I plot out this to see what the actuals are.  (Only the darker green ratios are really material.)   With Veloviewer I also analysed  the % time at speeds say above 35 km/h to try and determine how often did I really used the 44 - 11 combo.  (Less than 5% on my ave tar jolly it seems.  I also know I spend the most time on the 32t chainring)
I went with 1x11,  36 crank with 11 - 42 cassette (as I don't do tech trail steep climbing stuff etc - this might become my 'touring' bike for gravel and tar.)
So in the end I am losing a approx 2 km/h at the lower end and 8 km/h which I had with the 44 chain ring.  (Quite a jump with that last ratio, from 13 - 44 to 11 - 44.)
Time will tell :)
