Are either of the SafeSeal or Deed recommended for road tubeless.?
Will probably need to have a look at my sealant stocks at some point.
Another name that pops up under recommendations is Magic Milk.?
For road tubeless you can “use” any sealant but it’s recommended to use a sealant designed for the higher pressures of road wheels.
Something Joe’s road sealant. Or Continental
Just a side note to all using ammonia based sealants.
If you using a Shimano or mavic rim I would highly suggest you stop using the ammonia based sealant. The ammonia and the aluminum of these rims create a battery effect and this leads to a crater and hole forming (mostly around the valve) until the rim is throw away.
I would suggest using a ammonia free sealant like continental revo sealant or Joe’s eco sealant (recommended by Shimano for their wheels)
..but it’s recommended to use a sealant designed for the higher pressures of road wheels.
Yeah, I guess that's what I meant about the two mentioned products.
Thx.
