I have an annoying bottle cage on my road bike. Even smoothish roads, a 1/4 full to full bottle sounds like I'm stirring a bucket of rusty spanners. It's the cage on the down-tube and the same cage on the seat-tube is quiet.
I've considered putting some grip-tape on the cage to hold the bottle tighter, but would also like to not have holes in my bottles.
I could change the cage or the bottles, but if there's some sage advice out there, I'm all ears
What material is your bottle cage?  I remember long time ago my allu cages often made rattle noises (and they never lasted long).  For long now I use carbon cages and never had a problem.
Grip tape or tape around the bottle wont solve that sound.
It sounds like you have a loose bottle cage (or loose internal cable routing that you think is coming from the cage area)
Good old steel (or aluminium for the weight weenies) and just bend it so it holds em tighter. Ah, I miss the bad old days...
cage is carbon. It's definitely the bottle in the cage and not a loose cage as if I twist it a bit, the sound is gone, but returns a few bumps later
I once had an aluminium/metal cage that had unknowingly broken (couldn't see the break) and when the trail got rowdy the cage made a terrible noise.
If you have your bike tool kit and spares in a bottle (some riders do) cut up an old bike inner tube and use a roughly 10/12cm section and tie it around your bottle including the bottle cage binding them together. No more noise!
