Howzit everyone, I am wondering which of the two brakes you think is better. I define better as the best value, power and feel. I have heard that the G2 is a lot better from some people and others have said they noticed little to no difference.
I am really curious to hear your thoughts and opinions on the two brakes - currently leaning towards the G2, as it has slightly more power and is newer, but definitely open to options.
  On 6/22/2022 at 3:39 PM, DieselnDust said:
G@ has redesigned internals for better consistency and solved the seal issue that caused sometimes slow lever return. If your Guides have been updated post 2018 then they're essentially at G2 update
Expand
Thanks bru, just wondering if there is a power difference between them or not really?
I’m was very happy with the brake force produced by the Guide Ultimate I have. The force does build up progressively as you apply more leverage at the lever unlike Shimano that applies everything within the first few mm of piston movement
Expand
Ok shot bru, I don't like how shimano is all or nothing... Not very good for slow techy descents IMHO
  On 6/22/2022 at 5:44 PM, Headshot said:
Modulation is in your finger. If you have issues with Shimano braking you need to work on your braking skills. Cheaper, more power and no brake fluid. It's simple really.
Expand
Yeah to a point... I had shimanos and were able to ride fine with them, just prefer Sram.
But again parts for shimano is irritating
Also thanks for your involvement in this thread and I guess to each their own..
If we had to measure stopping time I bet there would be a sparrows fart difference between mist braking systems under normal usage. They all have similar mechanical advantage.
everything we perceive to be different is in the intangible’s and subtle design differences
Expand
And being able to find spare lever blades for when you crash them off, or spare internals if you pop a seal.
I went from Guide RSC to G2 noticed a big difference in feel and stopping power. G2 use a new type of brake pad as well which has worked well.
Id recommend the G2s
Whichever you go for, try for the RS model or higher. The swinglink means much more power than the lower end R model. Properly bedding in the discs and pads is vital whichever brakes you go for. I've ridden a set of Codes that felt like they had oil for pads. After sanding the pads and discs and bedding them in properly they were working as they should.
As for Shimano vs SRAM. Love my Codes and my Deore XT
