Floor pump parts
paul_ct
I thought this would be an easy fix, but am out of luck with the nearby bike shops. Can one get just the head for a floor pump? I don't need the hose.
Link to comment
Share on other sites
Thanks for those. I don't know why I didn't see that Takealot one when I searched, Luckily it's out of stock as it'd be the most expensive part of the pump. 💸
Link to comment
Evobike also lists the same part ... also out of stock.
Maybe call Janus and hear what they can get.
I have previously bought the pipe and head set at CWC ... was cheap back then.   Dont see it on their webpage now.
Link to comment
Thanks also. The sw one I saw made me think it should be quite a bit cheaper to find one without the hose. I'll probably go for the decathlon one.
Link to comment
Got a head from Olympic Cycles in Claremont recently.........OK, it was just before the Covid lockdown..........so maybe not THAT recently. Any good old fashioned bike shop with lots of stock should have one..
Link to comment
Olympic sorted me out. 👍
Link to comment
2 hours ago, Steady Spin said:
Same boat. But, I’m looking for the presta head for a Birzman pump.
Most of the pump heads are reversable and will work for both Presta and Scrader. Sometimes you just have to turn the rubber inserts around.
Link to comment
Found one at a local shop but it wasn't reversible unfortunately.
Link to comment
Check if it is perhaps a dual one. There are even some pump heads that work on both at the same time. No need to change anything. Scrader, Presta, no difference, just stick it in and pump (I know how that sounds, sorry).
Link to comment
I know it isn't a dual one because I checked :D :D :D
Link to comment
.....and bent the little thingy..........don't ask how I found out🤪
Edited by DJR
Link to comment
