Hi Hubbers, am looking for some advice on what the average lifespan of a carbon frame is, and at what stage one should consider upgrading to maintain performance levels. I have a Bianchi carbon frame that I have been riding for just over 2 years now, and have put between 7,000 and 8,000km on it. It still feels reasonably stiff, however I have been told recently that I should consider upgrading it as its 2 years old.
Opinions would be welcome on whether I should consider this, or rather keep riding it until I notice a marked deterioration in performance or something actually cracks. I'm not sure of the exact structural properties of carbon and the extent to which the fibre integrity deteriorates over time.
Help please Embarrassed
Thanks!
Are you so pro that you are actually able to tell if a frame goes limp? I'm sure it will not happen overnight so you will not pick it up if it does. Wash it with Viagra water and problem is solved.
Well consdering that Boeing make aircraft wings out of the fantastic plastic I don't think that a MTB frame will have a definate lifespan, short of crashing it I don't see why carbon should suddenly delaminate and fall apart.
Also dont think it happens overnight, I'm sure its only when you get on a new frame that you'd notice the difference.
Sounds like you have had experience with viagra? LOL
Well, seeing as Ive done around 20000km - 30000km a year and have ridden my frame for 4 years now, thats around 100000km on that one frame, I have felt stiffer frames as of late, but that could be contributed to the shape and build of the frame and not nesecerally that Ive ridden it PAP. Keep your frame, your interest in the frame will fade before it does. thats why people upgrade every year or two, thats those that can afford it.
Thanks bored girl - are you saying that only because you just got a nice new frame Wink???
Actually I am saying that because of our morning discussion smiley36.gif My new frame is alu, just like my old one...and believe it or not heavier than my old one. I cannot see what the advantage will be, to me, if I were to change to a carbon one.....
But thinking bout your question now.....Jules' frame is over 2 years old if I rememeber correctly, and I haven't heard him complain about it. Maybe when he wakes up he'd see this topic and give you his opinion smiley17.gifbored girl2009-05-28 01:03:04
If that is the excuse you need to upgrade/change, then go ahead and do it.
Sometimes our frames become soft to the eye after a few years and we need a fresher new oneWink
Since carbon doesn't have memory, it doesn't suffer from fatigue like a steel or alluminium frame.  Manufacturers are getting better at making stiffer frames ... just take a look at the headset and BB areas on new carbon frames (much more chunky / bulky than older frames).  So the new frames will definitely feel more rigid ... but that's not 'cause you've ridden your old one pap!
Hmmm, this is an interesting one. I've heard rumours/stories of carbon frames going "soft" after a few years, and in my mind that may be true about the early carbon frames.
I think that carbon fibre technology has improved alot over the last few years, allowing for better longer lasting frames. And although carbon frames does reduce road buzz, the resin bonding the carbon weaves doesn't have an "elasticity" element to it. Therefore it should never become "soft/stretchy", but would rather break or crack after many years of use.
I ride carbon frames for both road and mtb, and my advise would be to ride it until it breaks! Thats what I'm going to do Wink
jd, as long as it doesn't break on a rocky downhill Cry
how does a frame break ... instantly, with a snap? or would there be warning - would you notice cracks?
