I actually found by using a 160mm with a smaller surface area it works great as it doesnt build up as much heat
This doesn't make sense. I'm not arguing that 160mm disks stop well. There is nothing wrong with them.
But, if you have two disks, one with X surface are and the other with 1/2 X 2 surface area, the one with less surface area will be hotter after stopping the same rider on the same bike over the same distance.
It has to. It cannot dissipate the heat as fast. Heat generated at the pad/disc interface can only go two places - into the disc or backwards into the calliper. It goes both ways where it is dissipated into the air  by the larger surface areas of the hub, spokes, calliper and fork.
But' date=' if you have two disks, one with X surface are and the other with 1/2 X 2 surface area, the one with less surface area will be hotter after stopping the same rider on the same bike over the same distance.
JB is got to me as well. Before I had XT rotors which when doing some hectic downhill gave me brakefade, then I put on some Alligator Starlite rotors which are pimp but have less surface area and when I competed at the Mankele downhill race I had no fade whatsoever
Don't use discs but using my knowledge of heat sinks from PCs here. You need to consider the entire surface area. Drilled holes and decor will increase it. This will lead to faster cooling down of the disc.
It is just very possible that the design of one 160mm has a far greater surface area than a 180mm disc of a different design.
UPDATE: Here you can see the difference: The Alligator has a larger surface are due to its zig-zag design:
Alligator Starlite:
And XT:
cbrunsdon2010-01-18 13:55:05
rad006 - You need to compare apples to apples, perhaps there is something better about your starlite setup compared to the XT or maybe the one downhill required longer braking.
Fact is the smaller the rotor the quicker the heat build up.
Summit - are you trying to save weight by going smaller - or is there some other advantage?
Not at all, sure I like a fairly light bike, but my XX was supplied as such and there is more than enough braking power.
On my Scandal 29er I'm running 180mm up front and 160mm in the rear.
I just think that on a 29" wheel, a 160mm up front looks totally puny.
I just think that on a 29" wheel' date=' a 160mm up front looks totally puny.
Then imagine that 140 on Boris 29" rear wheel ....
Not at all' date=' sure I like a fairly light bike, but my XX was supplied as such and there is more than enough braking power.[/quote']
and the 140 at the back looks freakin' awesome.
Alligator Starlite:
And XT:
Lets consider the classic drilled disc.
The diameter of the hole is say, 6mm. Thus the surface area removed by the hole is 28.27mm^2
The surface area of the cylinder created by the 6mm hole in a 2mm disc is
simply circumference x 2 which is 18.85 x 2 = 37mm^2
Thus, there is a larger total surface area created by drilling holes. The question now is how useful that extra area is. Does air flow well enough over/through it?
Clearly the area gain increases as the disc gets thicker, but the airflow will decrease.
I dunno....where are the heat exchanger experts. Chickenrunforme - your phone is ringing. Come chip in.
Johan Bornman2010-01-19 02:01:56
To Answer the question, Yes the 180 disk has a greater ability to stop you by way of a bigger lever. The smaller disks look to have less surface area but in fact the extra holes and surfaces allow more air to cool the rotors faster than a standard plate type XT rotor.
going up to 180 plus extra air cooling...win win.
