Hi everyone! Could anyone please advise on how to make this bike lighter, without robbing a bank? Specs are as follows:
Cannondale Scalpel Ultimate 2011 frame
Fox loat RP23 rearshock
Lefty Speed Carbon DLR 110mm
Thomson Elite seatpost (31.6mmx410mm)
Selle Italia SLR Saddle
Cannondale Carbon SI cranks (manufactured by FSA) with BBB chainrings
Shimano XTR cluster
Shimano XTR chain
SRAM X.0 Jockey
SRAM X.0 gripshifts
SRAM X.7 front derailleur direct mount
Look Quarts Carbon Ti pedals
Shimano XTR M975 wheelset with Shimano Lefty hub on the front wheel
Schwalbe Rocket Ron non UST 26x2.10 tire @ the front
Rubena Charybdis Tubeless Supra 26x2.00 tyre @ the back
Shimano XTR M975 Hydraulic Disc brakes with XTR pads and discs.
Weight: one scale say 9.96kg, while another says 9.52kg. Thinking that 9.52kg sounds more accurate!
Wondered if anyone can help me to find ways to lighten this bike, without spending a lot of cash. Please advise :thumbup:
Thanks!
Edited by Scalpel2
wow, looks like you already robbed a bank! Nice bike!
I would say you could save a bit of weight on the brakeset and wheels, but from the weight you're at now, anything is going to cost a lot.
Lighter wheels.
Custom Build DT Swiss 240s hubs on ZTR Alpine rims.
Your other bet is to buy a SRAM 2x10 Groupset and sell this one of as spares.
Swap your brakes out for Formula R1's.
Configure your rotors for 160 in front and 140 at the back.
Maybe a ligter seat post if you can find one in that length. Lighter Handlebar.
Unfortunately, in cycling less is more.
Edited by Vivster
The Cannondale carbon crank is a pig in terms of weight. Cannondale Hollowgram SISL crank is a lot lighter, by several hundred grams.
While you are at it, go for a 2x9 drivetrain, or 2x10 if you can spend more.
The Stans Notubes MMX Podium wheels are a lot cheaper now (+/- R 6K) and will save you 300g over the XTRs. They are available with a lefty hub.
A full XX grouppo will save a few hundred grams
Lightweight wheels I built for my Scalpel:
From CRC:
ZTR Crest Rims R625 Each
Hope Pro 2 Evo Disc Rear From R1350
DT Swiss Revolution spokes for each wheel R300
Prices approx, Ex VAT & Shipping
I've used Project 321 Lefty Hub sourced direct $130 plus hub cap bolt kit $30
Cannondale Hollowgram crankset is very expensive if you can find one - Truvativ Noir is 800g
From CRC:
Sell what you have and buy a Scalpel Ultimate.....may work out cheaper ;)
When i upgraded from my sram/xtr/gripshift 2X9 groupset to full XX i lost a huge 70g so do your homework before you spend cash.Go 2x9 keep the gripshift and change as much as you can to kcnc.#My 2c
How much does this bike weigh that you're looking to trim some more fat?!? Is this the first known-case of bike anorexia?? :)
Seriously though - sweet bike man. Forget bout the potential 200g and rest assured that your dual suspension is lighter than most of the hardtails out there!
The Thomson seatpost is not the lightest out there but it is very strong. You can loose about 100g if you go to KCNC or maybe even 150g if you get a Tune.
Formula R1 brakes
Are R1's actually lighter?
If I've got it right thr R1's are 261g with upgraded levers while the Old Shimano XTR M975 is 217g standard!
Edited by Thumper
  • 4 weeks later...
How much does that carbon crank weigh? Do you maybe know?
