there was. They have pulled it for now as they are trying to resolve some issues which I am lead to believe has been done. Now just for the local agents to get stock
Oraait.
I saw a Quarg on a MTB.
It was customized to fit the crank.
  • Replies 358
Oraait.
i have seen something similar done with the quarg Riken but you are then limited but what blade you use. Running 1x11 I would want a 32 in front to help with the hills but the smallest I can get is a 34 and even then it is a custom blade Edited by Ramrod
Like this one am mate of mine is riding?
correct. Would you mind passing your mates details onto me. I would like to chat to him about his setup. Edited by Ramrod
  • 2 weeks later...
  • 2 months later...
I'm in the market for a power meter. I've made a spreadsheet of prices to give me a rough idea of how much each option will be.
https://docs.google....dit?usp=sharing
(I make no warranty of the accuracy.)
I think the Power2Max is going to be the best option for me.
Nice sheet. I would add support as another column. You can get some feedback on The Hub.
I will start. I own 2 Powertaps. The guys at Bicyclepower in Woodmead are amazing. They turn around stuff very quickly. On support they score a 10 in my book.
I had a Quarq previously. It had a few issues and it was always a issue to get it sorted. It always took weeks to get any parts and to get anything fixed. I will give them a 4.
I'm yet to hear anything bad about p2M
Lampre are riding with p2max to ensure there readings from Rotor are correct, says alot about p2max being use as the standard.
I see those Stages crank-arm strain gauge product is popular at Le Tour this year - elegant solution, from an engineering p.o.v.
Edited by kosmonooit
I also have 2 powertaps - a BIG +1 for the support from Bicyclepower and the quality of the kit - never had a tech problem with the kit that wasn't resolved the same day by BP in woodmead - and this is only one issue that was a config problem on my side... and some axle reconfiguration issues - again top notch service. Kudos to Dave and the team at Bicycepower - keep up the good work.....
one consideration is weight.
the hub based meters work very well, but i find the wheel weighs a frigging tonne.
However, this might not be a problem for you
cough cough, um maybe go look at our 46mm full carbon clincher wheel set, RRP only R20 995 weight 1590g thats 30g lighter than a set of Zipp 303 with a PT in it.......
the PT G3 is South Africa's lightest Power Meter...... net weight gain is less than 80g
