Hi there,
Got the Fizik Tundra 2 together with my Giant Anthem but the thing is killing me on longer rides (perhaps I'm just a softie?).
Will it get "softer" in time or should I rather just bite the bullet and buy an alternative saddle? And if so, what good options would you recommend?
Regards and thanking you in advance.
Guest Frail4Life
Hi there,
I say You need more Saddle time. Mine is very Comfy! It may just be Me?
Hi there,
Agreed. Fizik Tundra is crap hard. Had mine for 2 years and was in pain on every ride. Replaced it with a Specialized Avatar (R850) and haven't felt any discomfort since.
Go and have you sit bone measured, use that as a starting point then look at saddles that are the correct width for your sit bones.
+1
Saddles come in different widths, just like everyone's sit bones.
The Tundra is a narrow, hard flat saddle @ 125mm
Gobi is 130mm, but is nicely shaped
Antares is 142mm
Most Specialized saddles come in different widths.
So find a shop with an Assometer and choose an appropriate saddle.
I use a Gobi and sort of like it. Would love to try the Fizik Kurve range. They seem quite innovative and adjustable.
I've tried the Kurve range and 2 have broken seat bodies.
Not so happy as these were not cheapies, now on Antares and it seems fine, Gobi is good, maybe a bit heavy if you are a weight weenie
