They allo you to lower the pressure in your fork which enhances small hump sensitivity whilst making it more progressive
Can they be fitted to older 26" 426 Revelations? Edited by Skylark
  • Replies 2.1k
Yes. Tokens don't reduce the negative air chamber volume, they reduce the positive air chamber volume.
Luftkappe increases the negative air chamber volume, thereby making it more sensitive to small bumps and chatter.
Cool, I'm really interested. Just need to find someone who can
install it. I do most of the DIY on my bike except the suspension.
Pike RCT3 Solo Air 650b, 160mm
60psi (I think)
3 clicks LSC
12 to 14 clicks from fastest rebound
+- 95kg with kit
No tokens
65deg HA
2015 Nomad
Using most of the travel. Will try 4 tokens with lower pressure and faster rebound next.
Edited by Reden
60psi (I think)
3 clicks LSC
+- 95kg with kit
No tokens
65deg HA
2015 Nomad
Couldn't imagine riding with 4 tokens myself  :eek:
Was on two tokens on my pike, just gone down to 1 token on the Yari.
Pike RCT 3 Solo 160mm
75-80psi
105kg with kit
Mrp ramp control
65 degree HA
Rebound and slow speed compression changes depending on terrain and race.
Rebound generally fast.
pb-small.png This BlockLock headset from Acros prevents the handlebars from turning too far and causing the handlebars and shifters to smack into the top tube. In that respect, it's similar to Trek's KnockBlock system, but this version can be installed on any bike with a pressed headset.
pb-small.png There are 120 degrees of movement still available, and there are small rubber bumpers to dampen impact at lockout. It should take an impact of more than 150nm to start to twist the cup inside the frame.
So how has everyone got their Pike's/Lyrik's/Yari's set up these days?
SAG% - PSI?
Rider weight?
Number of tokens?
Bike head angle?
Bla bla bla...
So glad this question was asked. Made me revisit at my Pike's settings. Had way too much LSC. After bringing that down it just feels so much better sover the small bumps. Heavens know why I had it that high in the first place!
Yeah, I am now constantly fiddling with my Yari which sparked the question about what everyone else has done with their setup.
I have my Pike RC pretty dialed for my riding but just cant seem to nail the setup on the Yari.
I am almost ready to spend some cash on an after market damper. Maybe even a coil conversion kit.
