  • Replies 53
On the face of it it only seems as if outer sleeve is damaged, if it is not leaking you may get away with a patch job. however keep an eye on the patch to see whether it holds when pressure is applied under breaking.
If it leaks rather replace the whole line
Possible pratleys job
If you can find a male to male connector for that size pipe that could save you getting a new one, but this is all moot if you want to trust it 100% and if a new pipe is overboardly expensive.
Prestick?
Edit: I think its such a good idea I posted it twice.
Worth a shot. In my old days, i used it to closed a float on my weber carb. Did a bit of circuit racing, and used to experience a lot of fuel surges on certain corners. Mind you the pratley putty worked to close the float bowl. But didn't help with the surge, and to remove it was a complete nightmare.
What I'm trying to say there was a lot of pressure going thru the carb it worked. But i think in your case there's nothing for pratley putty to grip/hold onto....
Bleh bleh bleh.... Your cable is on its will msg you the tracking number
Hahahaha! Thanks dude!
Nice clean cut...so don't think it was from a fall?
Pretty sure that duct tape will work better than masking tape :ph34r:
hmm... sinister. if any tape were to work, it would be duct tape. Maybe wrap some cling wrap around it first. :whistling:
