BLITZKRIEG Posted September 27, 2013 Share Bamboo poles were cut from a forrest.The poles were then cut to the rough length needed for the various sections.The poles were then washed and the nodes punctured to avoid the tubes exploding during heat treatment.The poles were then heat treated, this is done three times first to remove the waxy layer then second to remove the chlorophyl layer and a lot of the moisture, i let them stand for about a week before i did the third treatment, this is to remove more moisture and give the poles a nice colour.. Caerus, Pieter1, Meezo and 3 others 6 Link to comment Share on other sites More sharing options...
BLITZKRIEG Posted September 27, 2013 Share A jig was then built (there are many ways in which to do this) and a parent frame chosen for the build. I copied the geometry of the frame in the picture.. I cut the frame up and took the necessary pieces i needed for the bamboo frame.. These all need to be ground in order for the epoxy to adhere properly.. The bamboo then needs to be cut and shaped to fit into the jig and onto the various pieces.. I will post more stuff tomorrow Duppie, braailegend, Jan Wyn and 13 others 16 Link to comment Share on other sites More sharing options...
Cav' Posted September 28, 2013 Share Mal! Link to comment Share on other sites More sharing options...
Woolf Posted September 28, 2013 Share Excellent work. Link to comment Share on other sites More sharing options...
jugheaddave Posted September 28, 2013 Share Looking awesome!! Link to comment Share on other sites More sharing options...
Beefy Posted September 28, 2013 Share Very impressive Link to comment Share on other sites More sharing options...
Vetseun Posted September 28, 2013 Share Wow!!! GOOD ON YOU MATE!!! Very impressive. Do keep us updated. Link to comment Share on other sites More sharing options...
Warren911 Posted September 28, 2013 Share Now this awesome. Good luck and keep the updates coming. Link to comment Share on other sites More sharing options...
hentus.matthee Posted September 28, 2013 Share I think this is an amazing idea. How long till you think until build will be finished? Link to comment Share on other sites More sharing options...
deanbean Posted September 28, 2013 Share It is finished. Look on the singlespeed thread. Amazing project. Link to comment Share on other sites More sharing options...
deanbean Posted September 28, 2013 Share Wouldn't it have been better to have lugged the bb? Made it stiffer? Link to comment Share on other sites More sharing options...
BLITZKRIEG Posted September 28, 2013 Share A lugged BB might have been stiffer but unfortunately the frame I bought didn't allow for that so I just used some more carbon in that area.. Link to comment Share on other sites More sharing options...
BLITZKRIEG Posted September 28, 2013 Share After all the pieces were mitred, I fitted the tubes together and made sure everything lined up. I then used a normal quick setting epoxy to glue the pieces together.. Link to comment Share on other sites More sharing options...
shaper Posted September 28, 2013 Share I liked the way you used a donar frame to creat your jig Link to comment Share on other sites More sharing options...
Skylark Posted September 28, 2013 Share Moar Pics!! Link to comment Share on other sites More sharing options...
BLITZKRIEG Posted September 28, 2013 Share I then sanded all the joints, I sanded the ends of each pole prior to gluing to make this part easier. For the rear stays I added a wedge to fill in the gap as the radius there was too tight to wrap in carbon neatly(you could give it a bash). I dont have any pictures of the carbon being layered on because it was very messy and I didn't want to get my camera dirty. When applying the carbon, just ensure that there are fibres in all directions.. Once you are satisfied with the amount of carbon, the joint must then be wrapped in insulation tape with the sticky side up, I perforeted the tape once it was on, this allows extra resin to seep out.. The particular resin I used was ampreg 21 and can cure at ambient temperatures.. The last picture is the finished joint.. Link to comment Share on other sites More sharing options...
Register a new accountSign in
