Conversion of 26" Giant Anthem X to 27.5"
grumpy
Hi Guys
Is there anyone who has converted a 26" Giant Anthem X to 27.5"?
I checked the chain stay distances on both the 26" and 27.5" Giants and the difference is 9mm if I recall correctly.
Thus if I am right the 27.5" wheel should fit (barely).
I don't want to buy new wheels and tires before getting confirmation that it will work
i went the other way ..... dropped my Anthem 29er down to 650 B
BB dropped 15mm only
rides well and i enjoy it
I submitted a post recently asking for cyclists who went from 29er to 27.5 with no response.
Would appreciated it you could share the reasons and what is better on the 27.5
bike turns easier , pedals with less effort .
bike is a little lighter and changes direction beta than 29
im not the fittest or fastest on a bike and find the 650 easier to ride.
im using ARDENT 27-5 x 2-25 tyres
find that im sitting more in the bike than on it as what can happen with some
26 converted to 27-5 bikes
BTW i own a silverback 650B syncra HT carbon
i ve got a scott ( older model ) spark converted
specialized stumpjumper in both 26 and 29 HT
sintesi 609 dual sus carbon in 26
so i have tried varies bikes and wheel sizes
Just be careful.
The chain stays normally narrow around the wheel (if that makes sense). A bigger wheel will therefore "move" into that narrowed section. The chainstay might be long enough to fit a 650b wheel, but the width between the two of them might not be wide enough. Some people overcome this by fitting a narrower 2.1 tyre, but this may not be enough.
Look at the stays from the top and try to visualise where the bigger wheel will end. Then compare that spot to the width of the tyre.
  • 2 years later...
Holy thread resurrection, batman!
And no. Different mounting points and changes to the dimensions. It'll probably fit, but not be ideal.
http://www.troll.me/images/resurrection-3/thread-dont-die-on-me-thumb.jpg
  • 3 months later...
Have converted a 26 " Anthem to a 29 er by replacing rear swing arm and front fork.  Yes head angle changed a bit but it turned out to be great for long distance endurance events.
