I have bought a bike that has a dropper post. Can you guys give me some tips on when, where and how to use it? I get that it allows you to lower your center of gravity but surely there is more to it than just that.
Edited by River Rat
There is no wrong or right way to be honest.
I drop my saddle whenever I get out of the saddle to ride a section. Even on some technical climbs it helps to not have the saddle to worry about.
You are welcome to join us for a ride sometime. It helps to see when other riders lower the saddle and for what type of terrain.
Welcome to the revolution!
What Maxxis and Sidewinder have said ...
Also drop it just before you get off your bike .. it makes dismouting and mounting so much easier ..
Basically it can be used anywhere, everywhere and all the time. Even on a long flat section of peddling, just to work different leg muscles ..
Why arent all bikes fitted with dropper posts, should be standard equipment !
DON"T "take the seat out of the equation" that could be VERY EINAs
Uphill UP (unless technical)
Downhill DOWN and everything in between
Just use it and experiment.
In any downhill I keep changing the position.
Changed my riding
Edited by porqui
Even just a 1" drop...
A 1 inch drop? Sounds hectic. :P
Besides what has already been mentioned I use it to:
Pin a series of downhill corners as it allows to move the bike exactly where you need it.
Set myself up for a bunnyhop or prejump.
Practise manualling and drop it half way for wheelies.
