I recently injured my right arm and have got a severe case of tennis elbow, and unfortunately it is going to take at 6 to 8 months to heal.
I have been off my MTB for about a month now, and rode again this weekend, only to find that changing the gears really hurts my arm alot. I have adjusted the gears every which way possible, but unfortunately the action of slightly twisting the wrist to change the gears really hurts my arm.
I then thought what if I change the gears around, and put the front on the right shifter, and the rear on the left.
It may take a bit of getting used to, but at least I can then continue riding pain free.
Anyone done this before, any advice?
Is that physically possible ? Just thinking the way it is designed it may well be difficult ....
Not physically possible with the shifters themselves, but surely one could just move the cables from one shifter to the other?
Have you though about using a grip-shift? Should be able to install this on either side.
Thought about that, but I was hoping to avoid spending alot of money on this.
SRAM are the only ones who do grip shifts, would those work with Shimano XT gears?
Theoretically yes I suppose, it'll be upside down but with the rapidfire+ multi release you'll stll be able to push to downshift put an awkward pull for upshift....
Best option would be a sram gripshift option, worst that could be is the wrong way around.
Theoretically, and someone should correct me if I'm wrong. It should work for up to 9 speed as the pull ratio's were the same up until then according to what I understand.
Another ludicrous option might be to stick on a road bike STI if the pull ratio's are the same for road and MTB
Or, friction shifters, since they don't really care which side they are.
http://static.jensonusa.com/images/Default-Image/Zoom/887/SL400A02.jpg
Edited by Vangar
The answer is simple...
just get a whole new bike! (Like a Trek Ticket SS or a Nukeproof Rook)
Then you can mount the shifter on your downtube
http://fstatic3.mtb-news.de/f/t8/u6/t8u6ewc5akoi/large_IMG_9538.JPG?0
Trek Ticket SS
http://p.vitalmtb.com/photos/users/109/photos/61714/s780_joy_v8a9313.jpg?1376818225
(Brandon Semenuk's bike)
http://ep1.pinkbike.org/p5pb8587134/p5pb8587134.jpg
Nuke Proof Rook
I see this as a win-win!
Not only will allow you to shift with your left hand...
But it will also improve your tail whips
http://www.nsmb.com/wp-content/uploads/2013/08/joyride-morgan-taylor-3137.jpg
http://spokemagazine.com/files/2011/07/9M3G7698-632x371.jpg
Or... if you're not into spending another 20k+ on a new setup, but you don't mind going all old-school-10sp-racer when it comes to your shifting, maybe you can just Macgyver something for your shifter to mount to your bottle cage bolts (easy enough if you're running X0 or X9).
Otherwie, like others said, Gripshift is your best option.
Edited by patches
Trek Ticket SS
Nuke Proof Rook
i dont think gripshift is an option, if memory serves SRAM use a 1-1 ratio where shimano use 1-1.1.
i have no idea what that means in reality but i suspect it is the distance each click moves the derailleur.
there was a thread a few months ago about offsetting the shimano gears to work with SRAM shifters or something like that.
I'm very inexperienced. But if there's one thing I've learned from a few upgrades, its that in the rear, sram and shimano shifters and derailleurs parts are NOT compatible. Or at least, not meant to be since they have different indexing systems. (I'm sure a few mad scientists out there have managed to make it work in certain cases though) Sram have however made a line of shifters called 'attack' that came in 8 and 9 speed some time back. They were entry level shifters that were meant to work with the shimano derailleurs only.
Anyways if it were me, I would run a single ring upfront and go the gripshift route for the left side of the bar. You wont need to run a longer cable as you are simply switching sides. its also way easier to become accustomed to shifting in this way as apposed to fiddling with your thumbs or fingers with a shifter which is either going to be the wrong way round or upside down
Edit: I forgot to mention. Shimano have a line of gripshifters called revoshift. So sram are not the only ones. its worth looking into.
Edited by popcorn_skollie
just swop swifters around and change with your left hand the upside down controls. No Problem!
However if you swop your rear brake all of a sudden to the left you might loop out a few times!!!!!!
or just go S/S
