Garmin 500/510/800 or Basic Odometer and Strava on iphone ?
Milosh
Hi All
So new bike needs new odometer ,  do I get a good Garmin that can do stuff or a basic and a water proof cover for iPhone and use Starva ?
You thoughts / opinions please
What do you do ?
Personal opinion.......the way these expensive Garmins (and others) tend to "jump" off and go walkies while out on your MTB........go for a "cheap" wireless odometer (i.e. CATEYE). The rest of the ride data assimilation you can leave up to your phone that is securely and safely tucked away.
The main con with using your phone is the battery life of a smartphone while using GPS.
The Garmin Edge 500 is great value for money!
Cant compare with between garmin and strava.
1. Garmin Looks better on a bike
2. Battery
3. U cannt see a phone screen under the sun.
4. U cant see ur cadence, heart rate, power and etc on ur phone
5.Gps (same distance but strava get much more elevation.
2. Battery
Agreed,
Stava and Endomondo way overstate your elevation sometimes bu more than 100%
Garmin 500 or Polar or similar.
Hi All
What do you do ?
Garmin 500. Done deal.
aaaaa....but you can.  ;)
Wahoo HR or an ANT+ adaptor
Stages shows up on the phone via Bluetooth.
All depends on equipment.
If you only want distance on you bike ride, go with a cheapy as suggested above.  No need for expensive stuff.
Ok so if going the Garmin route , which one will give you routing info  ie  Like map on car gps ,  take left hand fork etc etc
Or am I living in lala land ?
Cadance is nice,  Heart rate and power not  a biggy !
I believe both the 510 and 810 offer routing/direction on a map.
my personal suggestion - dont waste your money on an expensive head unit.
all the new power meters and heartrate monitors support bluetooth advanced, and most of the newer samsung phones support ant+.
i pretty much only use my bryton head unit as a backup. I use this app on my samsung (https://play.google.com/store/apps/details?id=com.iforpowell.android.ipbike&hl=en) with headphones. you can configure it to read out values (either only when you reach a max, or at intervals).
take the money you would have spent on a head unit and spend it on a power meter
I looked into this specifically for Jhb2C next year and the 510 can only do breadcrumb and not the full turn by turn navigation on a street map like the 810. I love the 810 but I think I will find more use for it if I start using a power meter. At the moment it does everything for me the 500/510 would have. The Bluetooth connectivity to your smart phone is an awesome feature though.
I would tend to agree... a good set of wheels and a power meter seems to be the best value for money if one wants help in perfomance improvements.
Only older 705, 800 or 810 has mapping functionality but needs to be added with sd card, my preference would be HR over cadence,
