Help me shed bike weight (and spend money...)
SiriS
Hi guys
So I had my Specialized Comp Carbon weighed at my LBS yesterday... 14.87kg!  :eek: So I want to trim this beast down a little bit and need some esteemed Hub help please.
Here's the original specs (XL frame):
CAMBER COMP 2014
CARBON 29
FRAMEFACT 9m carbon front triangle, 29" geometry, FACT TM construction, M5 rear triangle, tapered headtube, carbon PF30 BB, full internal shift/brake/post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 110mm travel
REAR SHOCKCustom FOX Float CTD Evolution, w/ AUTOSAG, Climb, Trail, Descend settings, reb adj., 197x48mm
FORKFOX Float CTD Evolution 29, air spring, tapered steerer, Climb, Trail, Descend settings and reb adj., 15mm thru-axle, 110mm travel
STEM Specialized Trail, 6061 alloy, 4-bolt, 8-degree rise, 6-degree rise, 31.8mm clamp
HANDLEBARS Specialized XC Mini-Riser, 6000 butted alloy, 720mm wide, 10mm rise, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, Others: XL thickness
FRONT BRAKE Formula C1, alloy caliper, metallic pad, S/M: 180mm, L/XL: 200mm rotor
REAR BRAKE Formula C1, alloy caliper, metallic pad, S/M: 160mm, L/XL: 180mm rotor
BRAKE LEVERS Formula C1, hydraulic disc, tooled reach adj.
FRONT DERAILLEURS RAM X7, 10-speed, S3 direct mount for DMD, bottom pull
REAR DERAILLEUR Shimano XT Shadow Plus, 10-speed, SGS long cage
SHIFT LEVERS Shimano SLX, 10-speed, trigger
CASSETTE SRAM PG-1030, 10-speed, 11-36
CHAINSRAM PC 1031, 10-speed, PowerLink
CRANKSET Custom SRAM S-1250, 10-speed Trail double, PF30 spindle, S: 170mm, Others: 175mm
CHAINRINGS 36/22, w/ alloy guard
BOTTOM BRACKET SRAM PF30, OS press-in bearings, sealed cartridge
RIMS Roval 29, alloy disc, 26mm wide, 32h
FRONT HUB Specialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32h
REAR HUB Specialized disc, 4x-sealed cartridge bearings, 12mm thru-axle, 142mm spacing, 32h
SPOKESDT Industry Stainless, 3X front/rear 2.0 PG
FRONT TIRESpecialized Ground Control, 2Bliss Ready, 29x2.3", foldable aramid bead, 60TPI
REAR TIRESpecialized Ground Control, 2Bliss Ready, 29x2.1", foldable aramid bead, 60 TPI
INNER TUBE
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Specialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SEAT BINDER 7050 hard anodized alloy collar, QR, 34.9mm
Roval 29 rims mated to Specialized Hi Lo hubs, oversized endcaps, 142mm rear hub spacing, and 12mm thru-axle increase wheel stiffness for more confident riding
Custom SRAM 10-speed Trail double-ring shifts fast while the PF30 spindle makes for an efficient and stiff crankset
Custom Formula C1 Racing brakes provide great braking power and modulation, while the Specialized Ground Control tires maintain traction and roll fast
Shimano XT Shadow Plus long cage, 10-speed rear derailleur is tough, lightweight, and delivers pinpoint shifts
I made the following upgrades:
1) XT brakes
2) XT front derailleur
3) About to change to XT shifters
Where else can I shed some decent weight?
Thanks!
  • Replies 66
Go Carbon on the handlebar,stem and seatpost and you could also have a look at XO carbon crank.
Then it starts getting very much expensive.
Not sure of the weight on the Roval wheels,but you could have look at something like Amercan Classic wheels or if you have the budget go carbon on them too.
The Fox CTD forks tend to be slightly heavier than their RoxShox counter part,you could have a look into that aswell.
You can remove the paint too, almost for free.
Cut the knobblies off your tyres
Drill holes in stem, crank arms, seat post
Run tubeless without sealant
Sure its easier to lose 3kgs of body weight rather than 3kgs off the bike. My estimate is that knocking 3kgs off the bike will cost R20-R30k.
Ya I would say buy a new bike. I wasted so much cash trying to make a heavy bike light. Eventually bought a new bike. Sell the bike , add the cash you are willing to spend and buy a new bike. Easiest way
What he said.
Or get decent wheels and go tubeless.
Get a ti seatpost and xx cassette
Lekker, I'll first go handlebar and seatpost carbon.
Also cassette yes.
Then wheels. Not sure if I should go carbon vs perhaps ZTRs or American Classics as suggested.
Might go 1x11 when the Shimanis become available later in the year.
Thanks guys!
Guest notmyname
Lawdy them spez boys make em robust.
Also cassette yes.
Thanks guys!
First port of call should be to go tubeless. Tubes are HEAVY!
Sorry, forgot to mention that tyres are already tubeless.
