  • Replies 18.2k
Actually, ZWIFT is something I have been doing some research on lately as I kit out a home gym.
I am probably going to get the RUNN device and set it up on our treadmill. Seems to be the easiest way to go about it. Just install it once and BOOM - Smart treadmill.
I like the Stryder POD, but can't face paying that amount of money for it.
Has anyone actually been running on Zwift (the last post in this thread about it was 2018) ?
I'm also planning to buy the RUNN, once the exchange rate improves probably. I also like the simplicity for using it for the whole family. And I like that it can broadcast incline. I don't think any other device can do that currently. Edited by ridr
Do you need to wear a mask while exercising?
You're supposed to wear a mask 100% of the time in public spaces. I don't have the exact wording here but I'm certain thats the gist of it. So yes, that would include exercise too I reckon.
i just did my first run with it. It’s great. Picks up cadence as well. Each family member has own Zwift profile with an iPad and we each took a turn to run. Was super easy.
Only downside so far is that the iPad does not pick up my heart rate.
Do you have a link for the Runn or is it the Runpod you are talking about?
If you using your Garmin strap then it is Ant+, you will need to get a dual BLE HR strap as ipad does not pick up Ant+ unless you connect a dongle, get something like the wahoo Tickr.  Then you will be able to use it with your ipad and garmin
Edited by shaper
I guess a Buff will work too? I use it at the shops and put a doubled tissue inside the fold, over the nose.
Ja, anything really, as long as it covers your mouth and nose.
A buff should be fine, I can run with a buff no problem. But I will pass out wearing a mask.
Zwift run does not control your treadmill incline yet.
Bluetooth on a treadmill usually is for music and not speed transmitting, some do transmit so check beforehand.
Dont buy a R300 foodpod, they all are shïtty.
I have a trojan 510 Ironman treadmill, the quick buttons only goes up to 12km/h but if you press the speed up button it goes much higher, check yours.
Zwiftpod is always a little bit off no matter how much you calibrate but it is still fun. If you dont have a pod download a treadmill bluetooth speed transmitter from the playstore. Only drawback is you cannot use the companion app the same time.
Technogym is selling refurbished commercial treadmills. Have fun.
In dont know wich one is harder, running with your face covered or running on the treadmill. Roads were quiet, only saw 3 other runners, 2 not wearing masks. I called 10111.
My concern after 6 weeks on the treadmill was that my legs would feel a little dead, but it literally felt as if the ground moved under me. Weirdest sensation.
And it was cold.
