Climbing with 9 Speed 12- 25t ultegra cassette on road bike
Mulalo.ramonedi
I god myself a road bike after two years riding an MTB(40% Off Road, 60% Road) riding.
I find it extremely hard to climb hills, the very same ones on the road i used to ride with my MTB.
My road bike is just under 10kg with pedals, my MTB was way above 15kg.
Will it get better with time or should i get the same Cassette setup i had on my MTB onto the road bike ?
The MTB was also 9 Speed, what should i take into consideration if i decide to go this route ?
Just pray harder
Must be the gear ratio: road bike ussually 53/39 (in front) while your mtb would probably have a 42/32/24...so you will be spinning more on the climbs with the mtb and grinding uphills on the road bike...
Maybe you should wait a month or so before changing anything...you might become use to the gear ratio on the road bike! If not, you can maybe change to an 11-28 or 12-27 casette at the back ^_^
Road bikes = *** off until you get stronger. The gears are not kind. You won't be able to fit a MTB cassette because a road derailleur doesn't have the range to accommodate it - as Reg says, the biggest you can go is 27 or 28 teeth at the back.
...pulled my old steel road bike out for a road race a few years back. Still had the old 52/42 up front and 12/21 at the back. We really used to crunch gears back in the day lol!
Where did you get a road bike that weighs 10kg? Take off a few kg's and the climbing will be easier.
Jokes aside that is the normal gearing on a road bike. A 9 speed cassette is a bit outdated but you should be able to climb up any hill with that. I have a 11 speed 11 /25. Riding the Cradle I don't get off the big chainring.
Years ago I bought and restored an Panasonic DX5000.
The guy had done a 2:45 on it in the Argus.
53/42 and 11/21 - Biopace nogal!
Those were hard men.
It works both ways.
I've ridden road for years, no hill too big no speed too high, recently got my first mtb and I am absolutely kakking with that thing.
Two different worlds, one set of legs. The legs just need time to adapt to a different style of riding.
Consider compact cranks if things don't work out as they are.
Go this route or get a 11-28 casette if you find the hills are still a problem...
It works both ways.
This is true. Road = power, MTB = torque. Two very different kinds of strength.
I run a 12/25 and a compact crank. The compact helps. took my wife down from a standard 53/43 to a compact and her avg speed improved.
Make sure your wheels and bearings everywhere is loose and working.
