What Oil to use.
Wannabe
Preparing to service the freebody of my Easton EA70 mtb wheel this weekend.
The spec sheet says a Hydraulic Mineral Oil must be used to lubricate the pawls, springs and ratchets.
What alternative can be used in the place of the oil depicted below?
http://gallery.mtbr.com/data/mtbr/500/medium/IMG_03502.jpg
hydraulic mineral oil :huh:
I'd think maybe a very soft grease but never oil
yep, mavic wheels also takes mineral oil, grease interferes with the pawls
Ai.
I have a set of 1998 Campag Chorus hubs that run like silk and freewheel like a dream. They have grease ports in the middle of the hub. Every few years or so I inject grease into the ports until the dirty grease coming out of the bearings on each side is clean. The grease goes right through the pawls and lubes them too.
Mineral oil shmineral oil.
Popped over to my LBS over lunch, they gave me a small bottle of the proper Shimano mineral oil, free of charge.
To reciprocate, I bought a few other consumables.
What he said!
A little goes a long way so no need to drown it.
Ai.
Some manufacturers do it right from the start  :thumbup:
Sooo, three people said hydraulic fluid/oil and two said grease. Sometimes the hub confuses me more than helping to learn [emoji2]
If ratchet and pawls are regularly serviced, then by all means use a good grease such as Motorex (http://www.motorex.com/index.cfm?oid=1147&lang=en&eintragId=126&webtoolDbTemp=eintragDetail) Poor quality grease could become gummy after time and prevent the pawls from engaging the ratchet. The return springs on the pawls are fairly delicate and the best option still remains using mineral oil and not grease.
Did not do the complete stripdown down to the pawls, as a special tool is needed (pictured below), but I did clean and lube as much as possible, and I can feel an improvement. Will test it on the trails this weekend.
http://www.parktool.com/assets/img/product/_thumb/FR-2_001.jpg
Got an idea to make one out of a socket that I will grind down to fit / work.
  • 4 months later...
http://www.custom-motorsport.de/images/product_images/original_images/dsc_0508.jpg
Can one use this mineral oil instead of Shimano mineral oil in your Shimano hydraulic brake system? Just a question?  :whistling:
